Question about SWANN Home Security
Servalence ccamera unit shuts down with a few minutes
Krazytech
  • 725 Answers
SOURCE: The unit runs for a few minutes and completely shuts down
Without the model or make sound like a bad thermostat..check amps the the compressor and voltage... if the compressor is locking up or the thermostat cutting voltage to it..
Hope this helps
Posted on Apr 05, 2008
  • 142 Answers
SOURCE: unit starts and stops to often
No this is not normal. You have a problem refered to as "short cycling". This is an indication of low refrigerant charge. You need to have the unit leak checked, repaired and recharged,
Posted on Jun 01, 2009
SOURCE: unit shuts down every five mutes
replace cooling fan
Posted on Jul 02, 2009
Samyfam
  • 379 Answers
SOURCE: After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Apr 27, 2010
sharcnet
  • 2130 Answers
SOURCE: the unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Posted on Jul 22, 2010
My dryer Kenmore DWJR ELE 2406028 FM64 stopped working. First it would stop at intervals. Now if I let the dryer cool, I can get it to run for a few minutes. It is over 10 years old.
Sounds like it is overheating. Clean your dryer vents and remember it is attached to GAS lines so don't pull on the cabinet. You can usually pop some hidden clips on the Dryer panels to remove them and access the inner workings of the machine.
Servall is a company which carries the dryer parts and may be helpful to you. They have a Website and sometimes have Diagrams you can use. You can also try the Kenmore Website for the photos.
If the dryer vents are clean, it sounds like a thermal switch is overheating and shutting the unit down.
Jan 25, 2012 | Dryers
The unit runs Ok for a few minutes and then shuts down.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
My compressor shuts off after a few minutes
Hello
One possibilty is the out side coils or condenser is dirty.And the unit is shutting down on high heat.
Try cleaning the outside coils with some simple green cleaner or even comet spray, then rinse with a hose.
May 27, 2010 | Frigidaire FAS296R2A Air Conditioner
The hot water shuts down for a few minuts then
your unit is undersized or you do not have enough gas supply to run the unit properly.
If you have to many water features running or you have to many gas items turn on at the same time it can cause problems.
Apr 10, 2010 | Rinnai Water Heaters
Sony Vaio will not turn on
plz check the powersupply unit , ram
Jun 22, 2009 | Sony VAIO PCG-K23 Notebook
Unit starts and stops to often
May 31, 2009 | Amana Heating & Cooling
Hope this helps
Apr 05, 2008 | Refrigerators
Home Security Logo
12 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
Da Doc
Outback Jack
Outback Jack
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
