Question about Medion md40298 Notebook
Mouse frozen mouse pointer frozen. this is a wireless mouse i have checked all batteres and there ok
After a few months, the keyboard works fine, the mouse will still click on the screen but it is frozen in place. After trying all of the advise I found online, nothing has worked. HELP!
try replacing the batteries in the mouse as this happens when the battery voltage gets below working voltage required
batteries last about 5 to 8 weeks then it freezes the pointer
Nov 13, 2015 | Onn Wireless Mouse M730r W/ Blue Optical...
How to fix pointer
Either your mouse has gone bad; if it's a wireless the battery might be dead; the mouse is disconnected; or your computer is frozen.
Aug 26, 2014 | E-Machines eMachines Desktop PC
Mouse is frozen..keyboard is not
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Nov 29, 2010 | Microsoft Standard Wireless Optical Mouse
Cursor jumps all over the place. My husband is ready to throw the computer away.
See if you are using Enhance pointer precision,if so try and turn it off. Click Start, click Run, type control mouse, and then click OK. Click the Pointer Options tab, click to clear the "Enhance pointer precision" check box,click Apply and OK. If you are using a wireless mouse try changing the battery.You can also go to the mouse control in the control panel.Uncheck the options to "automatically move pointer to default button". Also check the sesitivity of your touch pad , if it set to a high sensitivity and you barely touch it , it could register as a double click.
Nov 17, 2010 | Samsung N150 (36725723009) Netbook
Put wireless mouse on a pavilion dv6 3031tx lap top and it worked fine then the other day lap top batters went flat and now mouse will not move pointer yes it still installed and working correctly have...
Please uninstall the whole driver package and also clean the registry fo the software via START--RUN--REGEDIT- and re-install the same. It would work FINE
Sep 01, 2010 | Microsoft Wireless Mobile Mouse 3000
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Mouse Cursor Jumps to the right of the screen
Have you tried going into the control panel - mouse - pointer options - motion speed (slower) and experiment with pointer precision check box? Try it, see what that gets ya.
May 05, 2009 | Dynex Wireless Optical Laptop Mouse...
Mouse Pointer Disappears
Run a dianostic on your memory or add more to the system
Mar 30, 2009 | Microsoft Wireless Optical Mouse
My wireless mouse is not working and im trying to download free software
hi you need to check two basic things. first that either mose is not working properly or driver of that. try to re install the mouse driver and also plug your mouse in another system to check that mouse is ok or not
Mar 02, 2009 | Logitech 9311570403 Mouse
Pointer not moving. Tried everthing nothing works. New mouse, PS2 , light mouse , update drivers , unstalled and install mouse and usb ports . Its look good in device manager, everything looks goos and...
if you know how to boot up the computer and get into the bios than click on bios set up feature look for the ps2 and mouse and ensure it is set to auto and also there is a feature for turning on and off the usb ports in bios too so check to see that this is enabled then reboot this should help please let me know ok good luck
v/r mike
Aug 05, 2008 | Microsoft Windows XP Professional With...
Medion md40298 Notebook Logo
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
