Question about DeLonghi Coffee Makers & Espresso Machines
Download maps edge 605
On off button stuck
2 Suggested Answers
GPSCity Mike
  • 464 Answers
SOURCE: garmin 605 edge put in SDS card for mapping garmin has locked screen says keylock is on hold menu button to release have tried this garmin remains locked?
Do you mean microSD memory card?
What size is the microSD memory card?
A maximum 4GB microSD memory card should be used.
Does this only happen when the card is installed or does it happen without the card?
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Posted on Feb 08, 2012
Garmin 605 edge put in SDS card for mapping garmin has locked screen says keylock is on hold menu button to release have tried this garmin remains locked?
1-800-800-1020
Feb 03, 2012 | Garmin Edge 605 GPS Receiver
Sorry but honestly...Since GARMIN launch the EDGE this problem is still not resolved by them. The EDGE 305 had the same problems. Just search the www and you will see. My 705 died on me after just 2...
Edge 205 or 305 or 705 or 605 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Nov 01, 2010 | Garmin Edge 705 Handheld GPS Receiver
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Stuck on Archos screen...
well i got to tell you the truth mate archos are **** every mate of mine and me have all
expierenced this problem it will go from this to not
turning on at all - you wont lose your data it wont format
mine just doe sent turn on
Jul 23, 2009 | Archos 605 WiFi Digital Media Player
Uploading info from the Edge 305
Apperently my unit had some old data prior to my purchase, (amzon selling returned equipment I imagine)
Anyway, I did a hard reset, (turn the power on while holding the mode button down) Erases all history. I then paired up my accessories again, tested it in 1 second mode and smart recording mode. The hard reset seemed to work for me. My 305 edge is now downloading map and graph data to my PC. Hope this helps anyone with the same problem.
May 08, 2009 | Garmin Edge 305HR GPS Receiver
2001 pt cruiser codes po 605 and po 700
Diagnostic trouble code P0605 indicates internal Transmission Controller fault. Needs to be replaced
Jan 07, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Map code
I had the same problem. "Invalid Map Code", etc. I went to archos.com/gps_install, and followed the directions. I had to update my 605 wifi firmware. Once I did that, I entered my map code and map version (found the version on a .txt file on the dvd, forget which one), and followed the directions from there. Seems to be working so far, although I haven't actually taken it on the road yet (can't seem to get a GPS signal in my garage).
I'll post a follow-up once I know it's working.
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
How do I download games on the Archos 605
There are a lot of games you can download for Archs, but most games aren't created for it, so they won't work. Touch works and the game must be in the flash folder (you don't need to install it).
In he widgets -> flash it says empty also on my archos, but go to Files -> then the Flash map.
There you can find all the files, just select and run, Suc6!
Jan 13, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 is stuck in Demo mode
Should be the same as it was for my archos 604, try my instructions at
http://thepoetrydude2.blogspot.com
Dec 31, 2007 | Archos 605 Digital Media Player
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Oct 28, 2007 | Archos 605 Digital Media Player
Coffee Makers & Espresso Machines Logo
12 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
