Question about RCA Televison & Video
TV won't turn on
I have an RCA F20580wn. An oldie but, goodie that I inherited from my folks when I went to college. I have been unsuccessful in locating the manual in the house or online. I just recently moved and prior to that it worked perfectly. However, now it won't turn on. I want to say the first time I tried to turn it on I heard it "click" like it usually does when turned on but, it was noisy and I could be wrong because it hasn't "clicked" since that first possible time. Any thoughts? I follow specific directions well but am not very well versed in electronic thingamajigs. Thanks for your help!
  • 275 Answers
SOURCE: My TV will not turn on
I agree with techman. It is not a simple problem which a layman can resolve with his home tools kit. Best to get professional help. It will save you lots of bother (and money). The problem is definitely in the Power Supply (SMPS) circuits or the Horizontal Oscillator circuits.
Posted on Jun 27, 2006
  • 236 Answers
SOURCE: RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
IrishDruid
  • 2712 Answers
SOURCE: Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Posted on Jun 14, 2008
  • 166 Answers
SOURCE: clicking noise in the back of tv and wont come on no standby ligh
The TV is in protection mode because of a fault with moving it and then coming on briefly I would suspect that the fault is a dry joint ( a solder joint which has fractured) finding it can be time consuming but it is most likely to be around the caps in the line output stage which need resoldering.
SUPER8
Posted on Dec 01, 2008
  • 39 Answers
SOURCE: RCA 36' tube tv won't turn on
possible that a fuse blew while transferring tv, most like to happen despite care in handling if tv was on for a while, kind of like moving a light bulb that is hot and suddenly filament breaks when you move the bulb slightly. Other than that I'd say it's a good time to get a new tv just in time too for the digital transition.
Posted on Feb 06, 2009
How do I find Colby tv codes to program into a rca converter box remote
RCA converter box remote control have no set-up code to Coby.
Feb 28, 2015 | RCA Televison & Video
RCA TV won't turn on
If you have tried different electric outlets and it still doesn't work, then most likely the internal power supply has failed and needs repair.
Feb 10, 2014 | RCA Televison & Video
What is the point gap on a 1953 plymouth
Boy thats an oldie but goodie.
Should be .017 inches.
Sep 05, 2012 | Cars & Trucks
When I turn on my NES all I get is a black screen. Everything is turned on and plugged in the right place. What do I do?
ah the oldie but goodie. turn off the console remove the game blow in the console as well as the game. put the game back in and turn on. if it still doesn't work move the game from side to side just a little bit while pushing in and pressing the reset button it should work fine.
Aug 05, 2009 | Nintendo NES Console
Great old Jenn Air range needs advice!
YES THEY USE DIFRENT SWITCHES AND IF THE 1 YOU HAVE PROBLEN IS THE DUAL BURNER THER IS A SERVISE FLACH ON IT YOU NEED TO GO TO SERVISE MATER.COM AND FIND THE UPGRATE
Jan 25, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Resetting Channels without Original Remote
Buy a universal remote.
or
If there is no input button on the remote or TV, try the channels between 90-110, some RCA TVs have the A/V in there somewhere.
http://www.ecoustics.com/electronics/forum/home-video/134340.html
Oct 11, 2017 | Televison & Video
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
An oldie but goodie
i want CS330 driver
Feb 13, 2008 | Intel ICP3 Webcam
Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Nov 25, 2007 | Ovens
The viewfinder is dead
Thats an oldie but still a goodie.. this camcorder was made by Hitachi for RCA and its doubtfull that theres any parts available for it. You are probably gonna have to look around for someone with old camcorders laying around and swap out the veiwfinder . these units are also famous for the belts to go bad in them. if you take this unit to a servicer they probably have a flat rate as I've seen online under camcorder repairs unless you think you can do it your self?? Good Luck PS If I get a good look at the veiwfinder and if theres a plug or is it hard wired I may have one as I got several camcorders around the place i use for opsolete parts.
Apr 22, 2006 | RCA CC4252 Camcorder
Televison & Video Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
