Question about Refrigerators
Cannot remove the plastic light shield on the top of my GE Profile fridge to replace a light bulb
Have followed directions in the manual but the plastic shield will not budge
docjohn174
  • 943 Answers
SOURCE: GE Profile TBX22PC fridge water problems
hi thanks for the question you have a drain problem the drain tube from freezer to the drip pan behind and under neath the fridge you have to clean that drain sometimes you have to shut the fridge down for 24 hrs let the ice melt in the drain tube cause you cant get at it so let thaw and then clean out the drain hose thanks for your question the appliance doc
Posted on Sep 18, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Posted on Apr 08, 2009
VtToolMan
  • 704 Answers
SOURCE: Lights staying on
You need to replace the door switch, as it is allowing the interior light to stay on, but also it's keeping the fridge section circulating fan from coming on, and that is what is really causing the interior to heat up.
It's located in the top hinge plate cover and you can test for faulty operation by removing the switch and connecting or disconnecting the wires together to see if your light goes out and the circulating fan starts to run. If so, the switch needs to be replaced.
The part number is #6600JB3007K and costs about $8.00. You can order it from several online sellers or at www.searspartsdirect.com
Here's a diagram of your fridge and the parts list with pricing.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=LFX21971ST&productCategoryId=0161000&brandId=3204&modelName=BOTTOM-MOUNT-REFRIGERATOR&diagramPageId=00001&componentDescription=CASE%20PARTS&documentId=F0902046&backToLink=Return%20to%20Sub%20Components%20list
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
Do you have plastic replacement shield for light bulb for GE Exhaust Hood - Model JV347 0XIAA - Serial GS867119C ?
I'm betting 60 watt is much higher than the wattage recommended generating way too much heat in the confined space under the plastic shield. There should be a sticker in the bulb compartment listing the maximum wattage recommended.
Nov 23, 2014 | Heating & Cooling
Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01?
Hi, just follow the instruction below...
1. Essentially, open the oven door and remove the plastic vent strip between oven and microwave (4 screws). There will be 2 screws under that which secure the microwave unit to the frame. Remove those...
2. Open the microwave door and remove the plastic vent shield at the top (3 screws). At that point, the microwave unit will slide out from the frame as describe above. The light is to the rear of the large silver pad (I removed mine to facilitate reaching the light). If you look at the parts diagrams online, it will be obvious what to look for. I have the light out and sure enough, OSRAM 64405S....
Took me maybe 5 minutes to remove...
Take care
Apr 23, 2010 | Kitchen Ranges
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How the heck do you replace a simple lightbulb in the refrigerator of a ge ss double door? Very irksome that something that used to be so simple many people now have to ask for help.
I just looked at mine... it's a GE Profile as well and what I see is a plastic cover with the two temperature dial settings and the light behind the plastic cover. Once I removed everything from the top shelf, I simply reached to the back and under the plastic cover at the bottom and I was able to grab the light bulb and unscrew it with ease. It may look more difficult than it actually is.
Oct 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
There is no light in the fridge
Remove a plastic shield and replace the bulb. There is a special appliance bulb that will last longer than a regular bulb. Check for the correct size and wattage.
Jun 12, 2009 | Refrigerators
Ge top light Needs replacement
hi judy,
there should be 2 or 3 screws on the back that hold the top cover on, remove those and the cover should come right off. carefully twist the bulb out (it should twist toward the back)
you need a Whirlpool lamp part # 8009 or equivalent
Apr 05, 2008 | GE Profile JGS968 Gas Kitchen Range
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
