Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi vs 50607
The picture is rolling and stays dark for the first 20 mins, i was told that the pip card goes bad, if bad, how do i locate pip card
  • 3 Answers
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Posted on Nov 24, 2007
Horizonal picture rolls
the pip location is on the bottom part of the remote
Apr 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Dark at start up, lines on top
Replace Capacitors in the 9V regulator circuit..100uf 16V & 47uf 50V..May be listed as C2P04 & C2P05
Nov 07, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Sep 26, 2007 | Mitsubishi VS-5075 50" Rear Projection...
My Mitsubishi VS-60707 Problem...Need Help!
There are two common problems with this set that cause the symptoms you described. Both of them are caused by capacitors: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03. They are located on the signal PCB. Both capacitors are inexpensive and will more than likely solve your problem. Hope this helps.
Apr 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
PIP function
The Main Picture will eventually go out or at least become distorted. Generally the PIP circuit can be repaired by replacing a couple of capacitors. Probably a job for a Pro but it will need to be done at some point.
Apr 21, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Mitsubishi VS-50607 50" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
