Question about Kitchen Ranges
I have a Westinghouse Freestyle 472 gas oven that won't light .The igniter starts glowing the fan runs and the grill works but no gas seems to flow.I replaced valve thermal but still no gas flow.
2 Suggested Answers
SOURCE: I have a Westinghouse Freestyle
remove burner see if a hole is melted on glowing ignitor end repair with s/s welding if ok replace ignitor hsi assy w/o old 1 may appear ok but resistance values are out gas valve wont open if still dont work replace valve thermal hsi single should replace both these item anyway.this is assistance advice only do at own risk it worked for me madog cheers.
Posted on Oct 29, 2008
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Whirlpool SF315PEK oven pilot seems Ok but gas in oven wil not light. How do I check that the gas is flowing or if it needs to be adjusted?
If what your experiencing with the oven is that the oven igniter glows but their is no flame,the cause of that is going to be because the igniter is weak and not getting hot enough to open the gas valve and allow the gas to flow. I know it seems improbable that since the igniter glows that it's the problem but i tell ya with 100 assiduity that's exactly what the problem is. Replacing the igniter will fix your oven.
GENE
Sep 14, 2011 | Whirlpool GS460 Gas Kitchen Range
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
Grill will not light
Try replacing the regulator if you get no gas flow, or very weak gas flow. If you have gas flow and you are trying to light the grill with the ignitor. The rotary piezo ignitions must click with each turn, if they don't then they are bad and need to be replaced. If you have a new lynx with the glow plugs, check to see if they are glowing, if they are glowing and the grill has gas and still won't light, then the glow plugs are not getting hot enough which means you are leaking current somewhere and have to trace everything down to find the short.
Dec 22, 2009 | Lynx Grilling
The ignition coil on my oven glows fine, seems like there is no gas. Won't light.
it may glow but it s weak the gas wont flow
seems like alot of these going bad
I had 3 last week in my rentals
Nov 21, 2009 | Frigidare FGB24S5DC Gas Single Oven
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
The clock(computer?)broke so I replaced that part it seems to work. I then tried the oven it will not light. The ignition glows red but does not light the gas. I can smell gas. I tried lighting the oven...
Just because an igniter glows, does not necessarily mean it is good. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
It sounds like you may have had a couple of problems. The gas smell concerns me though. If an igniter is weak, you shouldn't get any gas flow in the oven. This is a designed safety feature that prevents free flowing gas from filling up the oven cavity without ignition. I would recommend checking your igniter for the proper current and/or replace. The link I provided, lists the steps required. If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Frigidaire GLGF377 Gas Kitchen Range
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
I have a Westinghouse Freestyle 472 gas oven that wont light. The igniter seems to start glowing, the fan runs and the grill works but no gas seems to flow.
May 14, 2008 | Kitchen Ranges
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
