Question about Epson TM T88 Thermal Printer
My auto cut is cutting twice
When the transaction is made the auto cut feature cuts a small strip from the bottom and top of the receipt leaving me with two small blank strips of paper with every purchase made. how can I correct it so that doesn't happen?
TabT
  • 14 Answers
SOURCE: Blank Strip Down the Middle
My guess is the fuser needs to be replaced.
Posted on Apr 23, 2007
Basti
  • 1447 Answers
SOURCE: unfinished printing cut-off
Are you using the APD304e driver for your printer? It has option where to cut paper, if not you can download driver from epsonexpert.com site, you will have to register first so that you will get a username and password. then go to technical resources, then select printer model then download driver
Posted on May 02, 2008
SOURCE: an extra cut about 1 inch after the invoice is printed
I am having a problem where the windows test page prints fine up to a point then it cuts the test page and does not finish printing to the part where it tells you this is the end of the test page. I am also using restaurant pro and was trying to fix the problem where it does not print the scanner bar at the end of the receipt. the rest prints fine all it put is the on hold and table number where the bar code should be any suggestions?
Posted on Nov 10, 2008
SOURCE: how to auto tear paper after printing receipt is completed.
I had the same problem, and after going through so many articles, I was getting the message but didn't know how to pass the escape codes. All you need to do is pass the ASCII code of the characters needed preceded by the ASCII code for Escape. In Delphi, we use Char(27) or #27. In my case I used ESC 105 Null and it worked. Here is my sample code, with Str being a TStrings class (A string array object) and the WriteTextFile being a procedure to write the Strings to LPT1 as plain text. Str.Add('*********END**********'); Str.Add(''); Str.Add(#10); Str.Add(#10); Str.Add(#27#105); WriteTextFile(dmMain.LPTFile, Str); any questions, holla me at gachugu@yahoo.com or igachugu@gmail.com
Posted on Jun 10, 2009
SOURCE: Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Posted on Jul 04, 2009
Which way up does a mountfield empress 16 blade go on? should the wings of the blade point upwards? It is cutting the grass, but leaving trails behind the machine and not filling the bag, so I wonder
The blades should have the cutting edge going forward and at the bottom so this is the lowest part of the blade. This means the wing should be at the top. If the blades are upside down they will be hard to drive and leave a mess of strips behind.
Sep 28, 2014 | Garden
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
Tsp100 not cutting receipt
the Auto-cutter on that model is only a 'partial' cut, (Guillotine-style.)
Since it is an Auto-cutter, if it is not cutting AT ALL, that is not something that a "user" can adjust-for.
See section 7-3 Releasing a Locked Cutter (pg 26) in your manual here:
http://get.acclivitysoftware.com/copdfs/TSP100PrinterManual.pdf
Nov 02, 2012 | Star Micronics TSP100 Thermal Printer
Print to a usb printer using cre 10.5, it prints plank small page at the top and at the bottom of each receipt printed. Can any one help
This is fixed by changing the document settings under windows properties for the printer, not in RPE. Right click on your printer and select properties. Choose printing preferences. Click Operations tab. Click End of Document button. In paper cut box, uncheck feed setting and move slider to manual cut. Click OK, then APPLY, then OK, OK.
In RPE, under Friendly Printer Settings, check Cut receipt at this station.
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Sep 09, 2011 | Pc America Restaurant Pro Express
My credit card receipts do not cut between the portion that the customer must sign, and the sales receipt portion. I'm forced to cut it manually. Has anyone else had this problem? Is there an option to...
In windows you have to set the printer to receipt printer and where you want it to cut the tape also check under setup or settings in pc charge then printers and then receipt printer there are functions you can change there as well.
www.greenlightpayments.com
Jul 18, 2009 | VeriFone PCCharge Pro Full Version for PC
Epson TM T88 Thermal Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
