Question about Canon Imagerunner 1025IF Grayscale Copier
Canon 1025if with no dial tone
No dial tone when pushing hook button
5 Suggested Answers
SOURCE: data processing light keeps flashing in fax mode
Unplug your USB cable and the fax should start working. If this fixes the issue, it could be a problem with your USB cable or hardware.
Posted on Mar 25, 2009
  • 92 Answers
SOURCE: We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Posted on Oct 27, 2009
canontech
  • 1219 Answers
SOURCE: Canon ImageRunner 1025if won't fax to #s, only email
Try to connect simple phone to fax line and try to dial a number of fax that you are calling from machine.If the line is ok then do the next:
press MENU and # ( service mode) with cursors go to clear, ok, clear all and ok.Turn off and on.
If that doesnt help call service.
Be carefull: the tel. line to fax machine must be connected in L slot, not in small picture of telephone.
Posted on Jun 16, 2010
muleskinner2
  • 270 Answers
SOURCE: nned to know how to set up the sped dial feature
Press additional functions
right arrow until you see address book, press OK. You should see 1- touch speed dial.
press OK
If you want the 01 position to be a number press OK.
Follow or answer prompts using OK until finished.
Posted on Jun 15, 2011
Nned to know how to set up the sped dial feature on the canon image runner 1025iF
press OK
Jun 08, 2011 | Canon Imagerunner 1025IF Grayscale Copier
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Jun 15, 2010 | Canon Imagerunner 1025IF Grayscale Copier
hello.
Oct 27, 2009 | Canon Office Equipment & Supplies
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
One of my agents unplugged the fax machine (Canon D880) and now it wont work at all. I printed a report of the settings and it looks fine but nothing works
Make sure the phone line is plugged into the correct input "Line" not "Phone" . Does the fax have an "On Hook" button that allows you to hear the dial tone? Have you tried a regular phone on the line to verify that there is a dial tone?
Jun 05, 2009 | Canon imageCLASS D880 All-In-One Laser...
Data processing light keeps flashing in fax mode
Mar 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Canon Imagerunner 1025IF Grayscale Copier Logo
42 people viewed this question
old marine
old marine
