Question about SNK Fratelli Onofri Royal Chiantishire FRRYC905S Dual Fuel Range
How to put the oven door back on a fratelli range
Handle loose on fratelli onofri royal chiantishire range
take off the whole door including the glass and possibly the lower shelf watch out for screws inside you can fix
Jun 19, 2012 | SNK Fratelli Onofri Royal Chiantishire...
Put oven on self cleaning and all it does now is beep and reads error f9. wont go back to where i can use stove top or oven
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#@%@#%%@
Mar 02, 2010 | Frigidaire PLEF398AC Electric Kitchen...
SNK Fratelli Evolution FREV905S-S Stainless Steel electonic clock and timer running slowly
This is from Tim at JMAppliances 2/24/2011:
These clocks are built to operate at 50 cycles(Europe) and 60 cycles(USA) and this is controlled by the audible alarm setting. The clock has to be set on the loudest (highest tone) alarm for the clock to operate at the correct setting. You control the loudness of the alarm by pushing the minus button (second from the right) repeatedly until you here the loudest (highest) sounding tone. Leave it at that setting and the clock will work fine.
Hope this helps
Feb 09, 2010 | SNK Fratelli Evolution FREV905S-S ...
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Putting on the oven door of a whirlpool gas range
You may need to pull the hinges away from the oven front to their first rest. That should allow for standing the door back on.
Nov 08, 2009 | Kitchen Ranges
My oven door fell off.
You need to put door back in the hinges , pull it up and slide it back.
If door does not fit, you may need to have hinges replaced.
See diagram below , click on picture to enlarge:
Mar 28, 2009 | KitchenAid KGST307 Gas Kitchen Range
Reinstalling oven door
be exstreamly careful do not put your fingers near the hinge. somehow pull the hinge apart till the stay open and you may see a hole in it, put somethjing like a nail into it to prevent it from snapping closed. then put it into the slots on the oven till they are in the right position then open the door all the way and then just pull out the nails. That is if it is that type of hinge.
Oct 30, 2008 | Roper FEP320 Electric Kitchen Range
Oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Oven door
it depends on the type of hinges, you would most likely have to push the hinges down and latch it with the small hook on both sides then put your door back on , push the door fully open ond unhook the small hooks.
Feb 18, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
SNK Fratelli Onofri Royal Chiantishire FRRYC905S  Dual Fuel  Range Logo
Top SNK Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a SNK Kitchen Range Expert? Answer questions, earn points and help others
