Question about ACCO 28-Sheet Commercial Electric Two-Hole Punch, Fixed 1/4" Holes, Platinu
Acco model 535 electric hole punch
Paper stuck, how to release it
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
C11-32
The issue is with the punch unit. It may have a bad connection. It may also be something stuck in the paper detect sensor or the sensor is broken. All possibilities are with the punch kit.
Feb 18, 2014 | Konica Minolta bizhub Office Equipment &...
Sircle Corp SircleBind CI-1500e Electric Spiral Binding Machine Jam
Hi Karen,
I would strongly suggest you find a local service technician to help you with this problem as the only way to release the pages is to wind over the electric motor by hand. To gain access to the motor the safety panels will have to be removed. The motor should be able to be wound backwards to release the punches from the pages, this will ensure the punches are not damaged.
If you attempt this repair yourself please make sure the machine's power cord is completely unpluged from the wall socket, not just turn off.
Dec 04, 2013 | Sircle Corp SircleBind CI-1500e Electric...
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
Cannot get the arm all the way up
this can be caused by excess paper stuck in the punch area. clean out all the excess paper, making sure to pay attention to the punch area. gently try to move the handle, it may take several tries to get the handle to move freely, make sure you clean out all excess paper before you use again.
Sep 23, 2013 | Swingline Swi-74650 Three-hole Punch - 3...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Swingline Model 525 electric 3 hole punch
It has a safety switch. This switch turns machine on when it detects paper and off if it doesn't. Something wrong with sensor. Broken, paper stuck under it, out of position. Will have to open it up and check the sensor. ***Always remember to unplug any equipment before working on it***
Apr 18, 2010 | Office Equipment & Supplies
Broken electric 3-hole punch
There are two phillips screws in the bottom. Once they are removed, the top and bottom of the case are held together with clips molded into the case. Take a wide flat screwdriver and place it in the seam and gently pry it apart. Might want to start on the back in case you ****** up the plastic.
Jan 22, 2009 | Office Equipment & Supplies
ACCO 28-Sheet Commercial Electric Two-Hole Punch, Fixed 1/4" Holes, Platinu Logo
439 people viewed this question
Top ACCO Office Equipment & Supplies Experts
k24674
Are you an ACCO Office Equipment and Supply Expert? Answer questions, earn points and help others
