Question about Performance Teknique ICBM-781 Digital MonoBlock Car Amplifier (1800W) Car Audio Amplifier
Whats the right way to brige the wire - Performance Teknique ICBM-781 Digital MonoBlock Car Amplifier (1800W) Car Audio Amplifier
HOW TO TELL IF PC POWER SUPPLY IS BAD
find a litle flex wire and brige green and black
Mar 15, 2014 | Computers & Internet
Electical
Hi it could be ign switch itself or imobilser .
Dec 15, 2013 | Jeep 2006 Grand Cherokee Laredo
Can i start my car even if the transmission switch range is not working ? if yes how? its a 2005 chevy impala
should be a plug in of wires on the side of trans. unplug it use a jumper wire when you find the right to wires it will start cut them tie them and tatape good caution it will start in gear by doing this
Mar 02, 2013 | 2000 Chevrolet Impala
I what to know how would i brige my speakers
if you have two speakers wire them up as usual but run them to only one channel on your amp.
Oct 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Engine light is on and sounds as though the rpms are too high
SOME ONE MAY HAVE LEFT THE DIAGNOSTIC BRIGE WIRE CONNECTED OR THE ECU IS FAULTY
Aug 30, 2009 | 2002 Chevrolet TrailBlazer
How do you wire sub speakers to change omes
if you have a 4ohm sub you can series it with another to make a 2ohm load. this is done by + from amp to + on one sub then take the - of that same sub and run it to the+ of the other sub then you only need to run a wire from - of that sub to the - on the amp. NOTE IF YOUR AMP IS BRIGED THIS IS A 1 OHM LOAD!! IF THE TOO SUBS ARE ON ONE CHANNEL THIS IS A Two OHM LOAD IF YOU ARE RUNNING 8 OHM SUBS THEN YOUR AT 4OHM PER CHANNEL AND 2 OHM BRIGED
Jun 13, 2009 | Kenwood KSC-WA82RC Car Subwoofer
How bridge the 15" 800 rms speakers audiobahn
parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Dec 16, 2008 | AudioBahn AWES15P 15" Subwoofer Car...
Car Audio & Video Logo
22 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
