Question about Brinkmann Camping, Backpacking & Hiking
Replace batteries in legend
How to get batteries out
How do I replace the battery in my Swiss Legend ceramic watch
Swiss Legend recommends that your watch be serviced for battery by a local and reputable jeweler in your area. For further advice on batteries, they recommend you contact them.
Email them at support@swisslegend.com or call 1-866-746-7794.
Good luck
Jul 25, 2010 | Swiss Legend SL-LUCERNE-ML134AC Wristwatch
My Pride Legend will slow down (barely move) after awhile of running. When it cools off, It will run ok again. What causes this?
The battery is probably overheating. Is this an original or older battery? Check the owner's manual for what kind of battery you should have and see if a replacement doesn't solve your problem.
May 12, 2010 | Pride Mobility Products Legend 4-Wheel...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Replaced the battery on a 92 legend and the battery light is on
HAve the alternator tested as well as make sure all wires are correctly connected and all fuses are ok.
Aug 10, 2009 | 1992 Acura Legend
Can't locate Internal Battery on Lucent Legend Control
The battery is on the proccessor but it is not replaceable. You need a flash backup card to save to and restore from. If the battery is dead it is either a very old system (which is okay) or there is something wrong that is putting a drain on the system. Try doing a backup before you shut it down and see if that can be restored
May 26, 2009 | Avaya Merlin Magix/Legend Control Units,...
Acura Legend Sedan 3.2 lts 1994
replace de ignition module first.. if still wont start good chances is the crank sensor is located behind the timing belt.. my 94 legend use to do the same thing until i replace the crank sensor.. and also if u can afford i will suggest u to replace the main fuel relay too... all this is after u are 100 pcnt sure that ur fuel pump is working....
Sep 26, 2008 | 1994 Acura Legend
Camping, Backpacking & Hiking Logo
Top Brinkmann Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Brinkmann Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
