Question about Faema Coffee Makers & Espresso Machines
Faema magica water pump - Faema Coffee Makers & Espresso Machines
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Trip switches of the boilers trip constantly on my faema machine. how can I fix it?
The element trip switches will go if the machine does not get water fast enough if they are not immersed in water, so to protect the element form overheating it will trip. Is there a sight glass to see the water level, I do not know what model Faema you have but most of the Due's have a sight glass on the left side front panel. Do you have a water filter and or softener, is that restricting the flow and need to be replaced, did the new ones if recently replaced get flushed before install, or maybe the water inlet tube where it connects to the boiler is blocked, has the technician checked and or cleaned that fitting? Can you use the manual fill to see haw fast water is getting into the boiler?
Mar 20, 2013 | Faema Coffee Makers & Espresso Machines
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
I am trying to get my Faema Contessa espresso machine to draw up the water from its holding container, any ideas on how to prime its pump?
Vibration pumps usually make this when they stay long without work, sometimes they are remaining useless after this, you can try to open steam valve and to try pumping inn the water, if it does not helps, YOU MUST open the device, remove pump and blow her with compressed air few times, (they have two sensitive non return valves on the outlet). After blowing try it with water outside the device and see if she draws. If you recover the old one just put it in place and continues to work. If not than you must buy new pump
Oct 18, 2009 | Faema FA60081
Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Faema S-87 Spouts copious amounts of water from the top
There could be one of 2 things happening :
1. Problem with auto level.
2. Most likely the inlet valve has a small leak.
Jan 26, 2009 | Faema FA60081
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
