Question about Maytag Washing Machines
Maytag washing machine Model LAW9406AAE not spinning tub
Not Spinning tub
ttech
  • 139 Answers
SOURCE: Maytag A108 27 years old
It sound like Transmission Problems,Bury it and give it a Decent Burial, Dont Forget to Give Thanx.....ttech
Posted on Jul 23, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 1294 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
SOURCE: WASHING MACHINE
Yes it agitates, but not spin
Posted on Apr 17, 2008
mikedurland
  • 481 Answers
SOURCE: Maytag neptune washing mach.mod. mhw2000aww
  • sounds like the drum bearing is bad, which also damaged the drum seal.
  • the drum bearing and seal is on the back of the washer under the large pulley.
  • the brown splatter is an indication of the leak.
Posted on Jul 04, 2008
Why does my Maytag washer fills all the way to the top no matter what setting it's on?
Pressure switch or a restriction in the hose from the pressure switch to tub. You may just have to disconnect from pressure switch and blow through it.
May 13, 2014 | Maytag Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
heatman101
Sep 15, 2010 | Maytag Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag washing mchine makes a loud noise when on spin.
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.
Mar 29, 2010 | Maytag Washing Machines
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Maytag Neptune FAV6800AWW top loader washer
Double posting, are you still having the issue, did reseating the clutch clear the issue?
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Sep 06, 2008 | Maytag Washing Machines
Washing Machines Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
