Question about Sewing Machines
I have a Singer sewing machine, it's old, model #5705C need info. on this model. Does any one know anything about this model?
I am unable to get bobbin, and casing back into machine.Is there a part missing?
SOURCE: Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Posted on Feb 01, 2008
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
kent581
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
  • 18 Answers
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
Posted on Jul 22, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
How do I get my bobbin holder back in my machine?
Unable to help without knowing the make & model machine. You may want to find a manual for your machine (search the internet for)
make model manual
Most bobbin cases have a spring-loaded latch that needs to be held open while the bobbin case is being inserted. When it is seated, the latch is released which locks it in place.
Nov 19, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
Singer 9420 bobbin case diagram
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
Missing tension spring screw?
You quickest and easiest fix is to buy a new bobbin case because screws are hard to find. A new bobbin case should cost less than $20 and any sewing machine dealer should have one.
sewman7
Mar 19, 2009 | Brother Sewing Machines
Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
Dec 19, 2008 | Brother CS-6000
Bobbin tension part missing
Buy a new bobbin case. It is the fastest,easiest way to fix the problem.
sewman7
Aug 28, 2008 | Singer 3116 Simple
Black bobbin case
If this is the machine I think it is the bobbin case is completely round as opposed to half round. If it is half round ignore the following.
Remove the presser foot and then the two screws which hold the needle plate. Lift off the needle plate and then lift out the old bobbin case. Clean all the lint out and then insert the bobbin case so that the less round part of it is to the back and the lip around the bobbin case is resting on the lip around the hook. Turn the hand wheel a few times to be sure it is working smoothly and not binding. Replace the Needle plate , bobbin and presser foot. Insert a new needle,thread the machine, Check your tension to be sure it is working correctly, turn the hand wheel again to be sure it is picking up the thread without binding and sew.
sewman7
Jul 07, 2008 | Singer 7442 Mechanical Sewing Machine
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
