Question about Refrigerators
Fridge/freezer too warm
We recently given a used KitchenAid KSRS25ILSS01. It was working/running when we went to pick it up, although it was empty and we didn't check the inside temp it 'felt' cool/cold. We brought it home, cleaned it up and plugged it no. Powered up but wouldn't cool. Determined the compressor wasn't coming on (it was before we brought it home). Replaced the start components. Compressor came on unit started to cool. Fast forward to 2 weeks later - neither the fridge or freezer have ever gotten quite cool enough. This unit has a digital temp setting, we have the freezer set at zero and fridge at 33 - both are the lowest settings. The freezer is about 8 degrees and the fridge is at 38-40. Nothing blocking any of the vents. The fan in the back of the unit next to the compressor is running. There is air flowing in both the fridge and freezer. There is no ice build up on the coils in the back of the freezer. Ideas? Thanks in advance!
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
  • 2920 Answers
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Posted on Jan 12, 2009
  • 17 Answers
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Posted on Feb 10, 2009
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
  • 43501 Answers
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Posted on Aug 12, 2010
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Control panel not working and fridge and freezer
You might have part of the answer in your own question - You would need to have it serviced - most likely the control board / electronic controls that has gone bad - this board controls compressor cycling and other functions of your refrigerator. Look for any error messages or blinking lights or a red service light if any - you could try unplugging your refrigerator for a few minutes and plug it in again if you are lucky and things reset otherwise have it checked. There is nothing much you can do on your own here without knowledge on the parts and how to locate it.
Other than control boards, if your compressor IS running but cooling takes a long time then check the condensers at the back if they are dirty, you need to keep those dust free and clean them about once or twice a year - warm, no cool, compressor running, I would then check for low refrigerant / leaks in the system (although rare). Most common problems affectin refrigerators are defrost timer problems, relays and controll boards going bad
Aug 17, 2009 | KitchenAid Refrigerators
Freezer wont defrost and refrigerator is to hot
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Jul 20, 2009 | KitchenAid KSRG25FK Side by Side...
Hello, We just bought a used ktrs20kawhoo KitchenAid top-freezer,that doesn't seem to be getting cold in fridge section. Freezer is fine. Does it automatically cool top first? The air vent is very small in...
Need to make sure both fans are working and the compressors is running all the time the fans are. If not we need to check the compressor for overheating and look behind back panel in freezer for frost build up. Let me know if you want my help, Sea Breeze
Jul 11, 2009 | KitchenAid KSBS25FK Side by Side...
I have the same problem...freezer is cold but fridge is warm
Jul 02, 2009 | Refrigerators
KitchenAid fridge model KSRA22KNSS overfreezing
Yes it sounds like the thermostat, depending onmodel you can change yourself. Here is a video that shows how to check your compressor is working correctly.
Nov 30, 2017 | KitchenAid KSRA22KNSS
Freezing fine,food area warm
themostat for food area is electrically loose
Feb 19, 2009 | Refrigerators
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
