When I set the flash to Auto, forced on, red-eye or any other flash function, the shutter won't fire and I get a message saying 'turn camera off and on again'. the ******* will only fire when the flash is set to off.
Are you sure you enabled flash through the options? Check the user manual for any setting related to flash before considering having the camera serviced:
Panasonic DMC FX33 manual
SOURCE: Lumix DMC-FX33 turns itself off
The message appears when force has been applied to the lens. You will probably need service.
SOURCE: Panasonic DMC-FX33 has operated perfectly for 3 +
Hello. If you suspect this is a lens problem ,I agree. I've had good results tapping the camera into the palm of my hand while its trying to open. Also try conecting your transfer cable to the camera and then press the power button, this keeps the viewing screen turned off sending full power to the lens mechanism. Lastly,and I should have mentioned it first,If you have a piece of exposed photo film,cut a small strip and work it in the gaps between the lens barrels to try to remove anything which may be stuck in there
builderdale
SOURCE: Lumix DMC-FX33. Keep on getting
I have the same problem. It resulted when we used the camera is windy conditions with very fine sand blowing around. Some of those grains are lodged in the automatic lens cover and in the autofocus/zoom mechanism in the lens. I can actually hear the grinding as the camera tries to open.
Now, how do I fix it?
SOURCE: When I try to take a photo in portrait mode with
dear sir,
the first suspect is your battery,which is running in low battery....kindly recharge the battery for few hours and then put your camera on........
next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest samsung service centre
thank you.....take care................
