Question about LG DLEX3360V Dryer
Reset switch on a dlex3360v dryer - LG DLEX3360V Dryer
2 Suggested Answers
  • 10865 Answers
SOURCE: Where can I get a dryer side vent kit for an LG
Hello chh... go to searspartsdirect.com
Have your model number ready. Enter your model number and you will be able to order what you need. Joe
Posted on Feb 20, 2011
Dryer model GTDP200EF1WS reset switch...where is it?
There is no reset switch. A dryer is a very simple device, a motor to rotate the drum and the blower, a heating element, a timer and a couple of safety switches for overheating, normally one that resets and one that doesn't.
You will find parts in the link. .
Dryer model GTDP200EF1WS reset switch Google Search
Feb 15, 2018 | Dryers
Lg dryer dlex3360v runs but does not heat
The reason why it runs with no heat is because the heater coil has just gone out you need to replace your heater coil in your dryer and then it'll work
Feb 07, 2018 | LG Dryers
Does the maytag dryer have a reset button. The dryer was working fine then just stopped turning on.
No, they typically don't have a reset button. But they do have safety switches which can fail. Usually there is a microswitch on the door. When the door is open the dryer won't start. Do you have power at all to the dryer? Do any lights light up? If not, you may have tripped your circuit breaker to the dryer and need to reset them. Typically there will be two breaker switches tied together to move as one in your power panel for your house or apartment. If you are not sure the breaker has tripped, it won't hurt anything to switch them off and then back on again. If this does not help, you likely have a failed switch or relay in the dryer that will need to be replaced. Also check that your lint trap does not have a switch which will prevent to dryer from running if you have too much lint in it.
Nov 04, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
LG electric dryer is not working
Reset your electric breakers and make sure the door switch is working. If not sure on switch after resetting breaker turn dryer on and with open door press the door switch in .caution keeps hands from inside in case it starts to work It also could be a Senser inside of dryer that goes off if vent is plugged with debri
May 27, 2014 | LG DLE2512W Electric Dryer
My dryer doesn't turn on. There is power but the start button isn't working
it may be the the door switch or you can try resetting the motor:
1) unplug dryer
2) put dryer on its front side
3) lift up the bottom of the dryer(so that you can see into it) you should see on the right side small red reset button.
4) push the reset button in.
5) put machine upright and plug in
If that does not work then you will have to short/jump out the door switch. Hope this helps Tim
Oct 02, 2010 | GE DBXR463EDWW Electric Dryer
The dryer wont start when i press the start button
maybe the dry door switch or the reset button on the motor. if you here like a click noise when you push the start button then its the reset. if not then more then likely it is the switch, which means either way the front panel has to come off, screws are located inside dryer door, the top corners are clipped from the inside so a flat tip screw driver will pop the corners, then disconnect switch, if it is the switch remove switch and tape wire together, put front panel on with top clips, plug in and push start drum should turn. get new switch.the reset buttons are on the motor and when you push the reset it will click. Hope this helped Tim
Sep 23, 2010 | Kenmore 63942 Dryer
Dryer won't start
Sep 23, 2010 | Frigidaire GLEQ2152ES Electric Dryer
DRYER WON'T START
No reset buttons. First check that the GFCI is not tripped. Then Check Circuit Breaker. Door Switch could be stuck. Could be bad start switch or timer
Apr 15, 2009 | Dryers
LG DLEX3360V Dryer Logo
88 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
