Question about Brother MFC-8860DN Printer
How do I reset the page counter for a Brother mfc 7365dn printer
I have changed the toner cartage and want to rest the page counter. How do I do that?
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Posted on Sep 23, 2008
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
techbuster
  • 5081 Answers
SOURCE: How do I reset the drum counter on MFC-9440CN
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
Posted on Aug 31, 2009
Testimonial: "THANK YOU THANK YOU THANK YOU Quick response and WONDERFUL HELP TO START MY MONDAY:)"
SOURCE: Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Posted on Feb 05, 2010
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem http://forum.testcopy.net/threads/how-to-reset-toner-cartridge-reset-counter-for-brother-mfc-7360-printer.1915/ Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
Brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Jul 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do I reset the counter for the drum unit on a Brother MFC 9840-CDW. It says to replace the drum but the unit is printing flawlessly.
On the TN-155 toner cartridge, a mechanical 'flag gear' that will reset the counter for each individual cartridge when first 'triggered'.
After each page print, the appropriate counters are incremented regardless of toner content (that is why it is still printing 'flawlessly') and after a pre-determined count has been reached, you will get a warning to change the drum as is will then be notionally (not actually) empty.
Before you decide to reset the 'flag gear' on the drum, make sure you are not actually nearing the physical empty state ... it might be a wiser decision to purchase a refill kit which should come with instruction on how to fill and reset the 'flag gear' (this needs some dismantling of the drum cartridge) or buy a compatible or genuine toner drum cartridge.
In any case, Google 'Brother drum flag gear' for more information.
Sep 20, 2011 | Brother MFC-9840CDW Laser Printer
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Resetting the counter for Brother HL 2040
wecan reset brother cartage 2ways. when we are filling at that time we can adjust white ringe of cartage. otherway after reffiling . and when we put cartage in side the printer. we should push white and black point and start the printer .then it wi be reset.(it is tech. private methode)
Jun 11, 2009 | Brother HL-2040 Laser Printer
How do you reset the page counter.
Most printers have a billing meter page you can print out that contains that information.
Go into reports and you should be able to have the machine print that information out for you.
Mar 01, 2008 | Brother MFC-8460N Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Press Clear/Back
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8860DN Printer Logo
559 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
