Question about Samsung LE40R74BDX 40 in. LCD Television
Does my samsung have a USB port - Samsung LE40R74BDX 40 in. LCD Television
Have a LN40D630 LCD Samsung TV. has transparent whitish block of horizontal lines across the top of the screen about 3" from the top down. The lines look like they are on top of the picture and are
AmanStino 3 USB Ports Car Charger with 1 Type C Prot
  • Input: DC12-24V.Output: DC5.0V 10.2A (3X2.4+3A).
  • High Speed charge for Apple and Samsung Series.
  • Extending USB Hub - Allow back seat passengers to easily charge devices.
  • Perfect for watching movies and playing games on long road trips.
  • With a 1.5m cable length,the 2-port HUB allows backseat passengers to easily charge their devices.
AmanStino 3 USB ports Car charger with 1 Type port AmanStino
Jan 28, 2015 | Samsung 40 LN40D630 LCD TV
One of my usb port is not working samsung laptop
Just use the others. You can get a 4/5 port extension that fits into any one USB (Working Port) for a few dollars. Each port allows additional USB devices to be added onto the original single port. Assuming you have TWO active ports, that translates to 8 USB ports min. Tiger Direct has them cheap.
Jan 08, 2014 | Samsung Computers & Internet
Samsung NP365E5C-S02US USB problem
In ten years of laptop repair I have seen many foreign objects stuck in USB ports preventing things from being plugged in correctly.
Jan 07, 2013 | Samsung 15.6" Laptop Computer -...
I got samsung la32b450c4. can u explain how can i use that usb port which reads service. or can i connect that service port to pc usb or is there any option to upgrade the software or something
Hello
First of all, it is not a USB port/slot, it is a 3.5 mm slot. And it can only be used Samsung technicians for "service" and nothing else.
Thanks for using Fixya!
Aug 25, 2011 | Samsung LE32A457 32 in. LCD TV
Where is the usb port for Samsung champ
Hi archana,
as per http://www.samsunghub.com/2010/10/25/samsung-champ-gt-c3303-review/ there is a USB port on Samsung Champ it is beside where the headset port is located (right side on top of the phone)
thanks,
Apr 25, 2011 | Computers & Internet
Samsung LA40C530 LCD USB limit
I have tested the LA40C530 Samsung with a 300GB external hard disk and it works well without any issue. My guess is that it should support 500GB as well. I have played video/music/pictures on my WD 300GB HDD.
Jul 01, 2010 | Samsung Televison & Video
Both usb ports does not work samaung x05
You need to reinstall your usb driver from Samsungs website.
Feb 03, 2010 | Samsung X05 Notebook
Music software of Samsung YH-925 20 GB MP3 can't regcognized the device
You may get the error that you're getting if there's a problem with the USB port of the computer, with the USB cable, or with the USB port of the device itself.
Try connecting the Samsung mp3 device to a different USB port of your computer. Usually, it's best to connect the device on the USB port at the back of the computer. Make sure that the USB cable is properly inserted on the USB port of the device and on the computer.
You may also try connecting the Samsung mp3 device to a different computer to isolate the problem.
Another isolation is to try connecting a different USB device on the computer, just to check if the USB ports of the computer is working properly.
Try using a different USB cable also, if you have any.
For more help: http://www.supportrix.com
Jul 30, 2008 | Samsung YH-925 MP3 Player
Usb
this may sound easy, but once you've installed the samsung software + drivers, plug the USB cable into one of the ports in the BACK of your PC - NOT the front ones (sometimes these are incorrectly setup, or not USB2 ports).
it's worth a shot before buying a new cable.
Jul 20, 2008 | Samsung Lands Phones
Hi just purchased Samsung j700 mobile phone. Trying to connect to PC with USB - seem unable to get driver to work - even the one on the disk?
that's the link with driver for samsung SGH J700 works perfectly with my phone
http://www.samsung.com/au/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=megapixelphone&model_nm=SGH-J700&disp_nm=SAMSUNG%20J700&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01011800
kisses all :*
May 18, 2008 | Cell Phones
Samsung LE40R74BDX 40 in. LCD Television Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
