Question about Refrigerators
Red ! on freezer
Hi I have a red exclamation mark on my beko ab910 temperature panel can you tell me what this means as I can not find the answer anywhere thanks. Karl.
SOURCE: I own a Beko AP930
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Posted on Jul 31, 2008
  • 44 Answers
SOURCE: top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Posted on Aug 25, 2009
  • 44 Answers
SOURCE: flashing light re temperature in fridge jenn air model
Your freezer may be a fan cooled system. Make sure that nothing is crammed up against the fan grill as this stops the air flow and probably causes the red light warning
Posted on Mar 28, 2010
miket756
  • 2702 Answers
SOURCE: hi can you tell me what the red explanation mark
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Posted on Jul 04, 2010
  • 5370 Answers
SOURCE: Freezer temperature is continually flashing
There is a fan in the freezer section.See if any ice frost is blocking the fan from spinning.If the fan is not running then its due to faulty fan.And this red light is indicating that fan has to be checked. -------------------- If there is frost collected on the coils and that is obstructing the fan then defrost it., -------------- unplug the unit for 4 hours then reconnect and see.If the problem returns again then defrost assembly and thermostat needs to be checked and replaced.This is the indication of defrost not working or the thermostat not cycling.this parts are to be replaced. in most of the cases,unplugging the unit for 4 hours then reconnecting will help.-------------to get part by part disassembly diagram for your refrigerator unit.please click on the link directly:-- http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JSD2789GES/1266/0165000?pathTaken=&prst=0&shdMod=JSD2789GES ----------------- This should help.thanks.Helpmech.
Posted on Jan 14, 2011
Beko fridge freezer I have square red sympol with an exclamation mark flashing
consult manual for trouble shooting or contact support through manufacturer website
Jul 23, 2016 | Beko Refrigerators
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
My BEKO AB910 is freezing the food in the bottom two shelves of the fridge section. MY wife commented it was making a louder noise than usual the day before this phemonena started. Any common faults...
My fridge did the same. What I tried, first check the airflow vents to see nothing blocking them. Then I put in a thermometer, as I had increased the temperature dial a month previous. Cold air drops, so the temp was 36-38 F as checked in the morning. I turned down the freezer a tiny bit and upped the refrigerator dial a tiny bit. This corrected the problem for me.
Oct 22, 2013 | Kenmore 64802 Top Freezer Refrigerator
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 | Freezers
Flashing light re temperature in fridge jenn air model
Mar 28, 2010 | Refrigerators
Top of freezer not freezing, bottom of fridge is?
Aug 24, 2009 | Refrigerators
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Fridge problem
means the temperature has gone up and freezer temperature is too high. fault should rectify itself given some time
May 11, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
