Question about Plumbing
I have to replace my well pressure switch alot
    Top Expert:
  • 3,698 Answers
Replace with a heavier duty switch. Make sure expantion air tank has air and nt water in it. If water logged drain and repressurize it.
Posted on Aug 20, 2014
F 1 error comes up alot and I have to restart the load 2-3 times
Hello
Fi error code means controller senses something wrong with pressure switch or water level signal
Check water level /pressure switch before replacing controller.Switch could have kinked /clogged hose
Or switch needs to be replaced.
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The oil light is on a beeping sound comes on like my seat belt is not fasten....it has oil in it....likes 1000 miles for an oil change
hello
Does the icon look like a oil can or is a oil life reminder light if it is a oil can icon then you need to check the vehicles oil pressure and make sure that it does have the correct amount of oil pressure and you have voltage to yhe oil pressure sending unit(switch) if it does then you need to replace the oil pressure sending unit(switch) seen alot of problem with the sending units
Good luck
Chris
Mar 22, 2011 | 2005 Buick Park Avenue
My 1997 jetta will not start sometimes if wiggle the key it fires right up
On this model car you will have to replace the ignition switch. This switch is behind the were the ignition key goes you get this problem if you have a heave key chain it puts alot of pressure on the plastic switch and it wears out the contacts .
Feb 08, 2011 | Volkswagen Jetta Cars & Trucks
What causes ge profile washer start filling up with water as soon as the spin cycle is through
most likely you either have a weak pressure switch or a water valve that is not seating properly... if when the unit is off it does not fill on you then it most likely is going to be a pressure switch located in the console area... prior to replacement though make sure the clear hose that goes from the pressure switch to the side of tub is not damaged or disconnected from the switch itself...alot of times if there is a crack and it cannot hold the pressure switch closed it will open and allow water to continue to run... the operation is as follows: turning the timer to a wash cycle water fills to desired load level once reached the pressure of the water in the tub will send air up to the pressure switch telling it to close once closed the timer advances to the next level of the wash cycle and the power is shut off from the pressure switch and water valve.... hope this helps a little ....
Jan 02, 2011 | GE Profile WPRE6150K Top Load Washer
Would a bad Oil Pressure Switch jeep grand
it certainly can .......... the switch is cheap enough to replace too
Nov 14, 2009 | 1993 Jeep Grand Cherokee
Low oil pressure in 1998 camaro ls1
First have your oil level checked and make sure that it is at the right level. If not that's your problem, if your level is good you may have a bad oil pressure switch. This can be checked by using a oil pressure guage. If switch is bad replace and solve the problem. However if your vehicle has alot of wear and tear on he engine and you were using 20w-50 oil and it was replaced with 5w-30 that oil may be too "light" for the vehicle and you would get a low oil pressure reading. Good Luck
Dec 15, 2008 | 1998 Chevrolet Camaro
01 grand cherokee fan relay/oil pressure
I don't know if this will help anyone, but i had a issue with my jeep running hot and check engine light coming on as well. After alot of trips to different shops - the last one found that there were two senors in the engine for the fan that need to be changed. Everyone would aways fine the one up top but not the second one. After that, have not had any other problems like it since.
Jun 17, 2008 | 2001 Jeep Grand Cherokee
Plumbing Logo
233 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
