Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
What remote will work on a phillips magnavox tl7119 c227 to get it out of hotel mode?
I have the tv but need to buy a remote and it has to be able to get in and out of hotel mode. i need a master remote. what remote should i buy?
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
  • 1153 Answers
SOURCE: tune up tv
sounds like convergence problems.
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: NEED USED SCREEN FOR PROJECTION TV
I have an 9P6040C101 that i am selling off parts.
I did sell the mesh screen, but i have the protection screen and everything else.
443-255-1892
Posted on Jan 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 03, 2008
SOURCE: Phillips Magnavox 9P6031C103
Yah go to searspartdirect.com and type in the model number the screen is available after market but is authorized for use by phillips it run about $335 dollars if thats to much check local craigs list or tv shops they sometimes have brokes tvs with good screens
Posted on Sep 12, 2008
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
Brightstar br100z remote for a magnavox?
Brightstar (and similar) remotes are used in hotels and are uniquely coded so they don't depart along with a guest. Your only solution is to replace the remote
Nov 28, 2012 | Televison & Video
We bought a magnavox tv from a hotel and some channels are blocked and we can't get all of our cable channels. Is there a way to reprogram the tv? It is a 25' and it's about 10 years old and in good shape....
the eprom that holds the stored codes needs to be wiped clean or re-set...unfortunately, unless the original remote is available to get into the menu...it will have to be done manually by a technician. the set needs to be opened, the eprom located, the proper pin-outs located and then proceed with resetting. if the eprom is an older type, then the codes were usually held there by a back up battery or super cap...in which case, you just need to remove the battery or super cap for a couple minutes.
silvio
Jun 30, 2009 | Philips Magnavox 27MS343S 27" TV
Can't find menu on hotel tv
YOU WILL NEED THE SPECIAL REMOTE TO DO THIS. AND I THINK SOME OF THEM HAVE ABILITY IN SERVICE MENU TO TURN OFF HOTEL MODE. OR YOU CAN TRY USING ANY PHILLIPS/MAGNAVOX REMOTE WITH THE STATUS BUTTON AND TRY THIS.
PRESS MENU-9-6-5-2-STATUS AND YOU SHOULD BE IN THE SERVICE MODE TURN OFF THE HOTEL MODE
Jan 03, 2009 | Mitsubishi CS-35707 35" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
ZN110 remote
Magnavox codes 002,009,109,118,309,402,408,502,508,510,807, 917
May 11, 2008 | Zenith ZN110 Remote Control
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Dec 01, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
