Question about Kingston Computers & Internet
Dtse9 kingston problem
It tuned the folders to shortcuts
Why in my pendrive all the data we trancefer are come in shortcut
Probably you just copied a shortcut to the location of the files. You need to go back and verify whether this is the case.
Oct 05, 2014 | Kingston Digital 4GB DATATRAVELER C10...
Kingston DTSE9 32GB USB 2.0 Flash Drive
A few important bits of information about using faults and fixes on usb drives
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see
click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box
(I have found better results ticking the first box then return and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
also you might need to do this
Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply.
Feb 15, 2014 | Kingston DTSE9 32GB USB 2.0 Flash Drive
I have a kingston 8gb, and when I insert my usb I cannot locate the file anywhere. I also use a mac and have tried using the finder to locate the kingston file and it is no where to be found. The hard...
You will need to locate the USB drive by opening Windows Explorer, and navigating to the "My Computer" folder. (You may have a shortcut on your desktop for this, if not, you can tell the computer you want one from your "Control Panel" menu) USB Drives will be listed as removeable drives, usually with drive letters D, E, F, G, H, etc..
Click that, and there you go!
Nov 20, 2013 | Kingston Computers & Internet
Can't find my Google icon
Fix All My Computer Shortcut Links
Computers often use shortcut links to make it easier for users to locate and open files.
These links are commonly placed in a folder easily accessible to users, such as a desktop folder.
When a shortcut is created, it is given directory information and an icon.
If the file associated with a shortcut is later moved, the shortcut may fail to locate the file.
When this problem occurs, you need to update the shortcut's directory information.
This process is often automated by operating systems, but in a some instances, you need to repair shortcuts manually
Right-click on a broken shortcut link's icon.
Select the "Properties" option. Locate the "Target" box and copy its information into your clipboard using the Ctrl and C keys.
Open the "My Computer" folder on your computer and paste the target information into the folder's address bar using the Ctrl and V keys.
If the address bar is not viewable, you may need to enable it in the folder's settings.
Find address bar options in the "View" menu under "Toolbars."
The file's target path folder will open.
Locate the file in the target path folder.
If the file is not present, the target path is inaccurate and likely the cause of the shortcut link error.
Locate the file in its correct folder.
Browse folders or search for the file by typing the file name into the "Start" menu.
After finding the file, open the properties of the shortcut link icon again.
Copy the file's correct path, from the containing folder's address bar, and paste it in to the "Target" box, replacing the incorrect link.
Another way to find a file's target path is by right clicking on the file and selecting Properties.
You can find accurate target information in the "Target" box, provided the icon is the original file icon and not a shortcut.
Aug 11, 2013 | Computers & Internet
Start
Jun 07, 2013 | IwantSoft Free Keylogger
Write protected kingston dtse9
w7
also
Click permissions
restore defaults
In XP
Mar 02, 2013 | Kingston DTSE9 32GB USB 2.0 Flash Drive
I have a kingston memory stick. What is a burn folder?
You will need to connect / plug in your Kingston data stick to a computer once connected Click start all programs accessories open windows explorer navigate to your Kingston drive it could be E: or something might be listed as a mass storage device open it up you should see all of the data inside. First make a folder in your Kingston Drive click start all programs accessories My Documents you will see your Kingston drive open then right click select new folder and name Burn Back up for an easy location find.
or click start click on computer you should see your drives and your Kingston Drive Right click on the data you need to be saved right click select copy navigate back to the destination drive it could be a another drive or E: drive in my documents right click select paste or hold the mouse cursor the Data drag them to destination folder then drop the Data in to your newly made folder Burn Back up back up. If you need more help with this post a reply
Feb 09, 2013 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
Jan 09, 2009 | Acer Aspireā„¢ T180 PC Desktop
Kingston pen drive folder and zip folder not to see data
2) How to put Slax on CD:
http://www.fixya.com/support/r3879348-slax_guide_survival_live_linux_usb_flash
or
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 13, 2008 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
