Question about Dishwashers
Candy futura cdf 8 312 - Dishwashers
Need a door shelf for my CANDY FUTURA A class fridge freezer.
Fixya does not sell replacement shelves. Check with a local appliance parts supplier.
Nov 14, 2016 | Candy Refrigerators
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
I have a Candy Futura Fridge Freezer and the fridge keeps getting a build up of water. The freezer seems ok
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Candy CPCA240FFK Bottom Freezer...
Candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Our Cuisinart deep fryer, model number CDF-100 is just over a year old and has simply stopped working. What is the warranty and how do we get it fixed or replaced
The CDF-100 has a 3-year warranty - call Cuisinart at 1-800-726-0190 and see if they can help you with a replacement.
Jun 27, 2009 | Cuisinart DCC-2000
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
Aug 28, 2008 | Candy CPCA240FFK Bottom Freezer...
Dishwashers Logo
Top Dishwashers Experts
