Question about Lands Phones
My BT Studio 4100 Plus handset 2 had stopped working when the phone rings and we answer it it just makes a crackling sound and their is no dialing tone to call out the handset no 1 is ok
  • 146 Answers
SOURCE: No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
Posted on Jan 14, 2008
SOURCE: BT Studio 1000 4 handsets
hi problem with bt studio 1000 phone changed battery and phone still not working just a hi pitch sound when you press it .
please can you help me.
Posted on Oct 27, 2008
SOURCE: both phones are flashing base
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Posted on May 16, 2009
  • 5 Answers
SOURCE: No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Posted on Mar 04, 2010
  • 225 Answers
SOURCE: Phone (base and both handsets) rings once, then
This is likely caused by a trouble from the service provider. It is caused by a partial short on the phone line. The service provider can usually test the line remotely when you call the trouble in. Occasionally this problem is caused by faulty equipment(phone, answer machine, modem, etc.), bad line cord, bad outlet or bad building wiring. Inside the outside telephone interface box there is a modular test jack that has a short line cord connected. Remove this line cord and connect a standard telephone to test the phone line. Make a call to your number, if the problem occurs with the phone connected to the test jack, then the problem is with the service provider. If the problem does not occur with the phone connected to the test jack then the problem is in the building wiring, outlets, line cords or devices connected. Use a process of elimination to determine where the problem is. Example: disconnect all phones and devices and line cords, make test call with one phone connected, if problem continues inspect outlets and wiring.
Posted on Dec 29, 2010
Testimonial: "Our phone actually started working correctly again, so I think you were correct in saying it was the service provider. Thank you for your help!"
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
No Dial Tone from BT Diverse 7110 Single
Check that the volume on the handset is turned up, also replace the batteries or put in non-rechargeable ones to get the phone working at full capacity. If bought from Amazon you should be guaranteed for a year, not a month!
Mar 03, 2014 | BT Diverse 7110 Plus Cordless Phone - DECT...
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
BT Studio 3500, Base station, flashing telephone. Base staion handset, flashing message icon 2nd handset, flashing telephone and handset. Why the flashing and how do I cancel all the flashing.
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
Sep 17, 2008 | Lands Phones
We have BT Studio 1100 with three handsets. From working well, they all became dead. We have changed the batteries. The phone line is working, and there is electricity reaching all the cradles which...
I have the same phone but with two handsets. Incoming calls only ring on the base and I cannot answer or make calls as the handset is permanently flassing "base 1". I have tried disconnecting and reconnecting. Also tried to restart setup but this is showing unavailable although I can still access the phone menus.
Jul 01, 2008 | Lands Phones
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
No Dial Tone
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
