Question about Janome Sewing Machines
The bobbin winder on my Janome (new Home) Memorycraft 7000 won't wind - motor sounds like it is turning, but spindle barely moves
Bobbin winder on my Memorycraft 7000 has stopped working - motor sounds normal, but spindle not moving, even though thoroughly engaged into bobbin winding position - display screen says 'bobbin winding
5 Suggested Answers
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
SOURCE: Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Posted on Feb 15, 2009
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
  • 980 Answers
SOURCE: bobbin winder stopped working
Either the winder rubber has worn down, or there may be some residue on the winder rubber, ot the winder may have seized through lack of oil which is quite common in that case it will need to be replaced
Posted on Mar 23, 2010
Testimonial: "This is helpful can I fix it or do I need to take to a repair person?"
Hello. i have the memory craff 7000 janome but i can go back to normal sew after i use the bobbing winding, i don not what i can do. thank
I don't know your machine but on most you have to move something to wind a bobbin, you have possibly forgotten to put the bobbin winder back into sewing position.
Jan 28, 2015 | Janome Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
Husqvarna mega quilter
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Bobbin is not filling. It barely turns.
This happened on my Janome 10000...it had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Wind bobbin on Decor Excel 5018
Once you have the thread guided and the bobbin is on the thread winder spindle, push the bobbin to the right.  The machine will not sew again until the spindle is in the left position.
Feb 03, 2009 | Janome D'cor Excel 5018
sewman7
Nov 25, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
