Question about Cardiac Science survivalink AED Defibrillator
Call for service light
The call for service light has come on
Service 4wd light is on
The Internet, though, has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors.
Here is just a sampling of what sites are out there:
Factory Auto manuals
http://www.factoryautomanuals.com/
search for : factory service auto repair manuals
Repair Service Manuals
http://www.repairservicemanuals.com/
the largest collection of Automotive Repair Service
Manuals and Owners Guides on the internet. Our
database currently holds over 54,000 entries
dating back from 1940 to more recent 2011.
about Chilton Repair Manuals
http://www.chilton.cengage.com/
about Haynes Repair Manuals
Haynes Publishing
Haynes auto manuals
http://www.haynes.com/
Jan 15, 2016 | 2002 Dodge Dakota Club Cab
How to turn off service light oil change light and service spanner light on renault megane 2008 petrol
you may have to use a scanner to reset the CPU for this unless there is something in the owners hand book on how to reset after a service.
May 10, 2014 | 2008 Renault Megane 1.4
RED LIGHT INDICATING OIL SERVICE
Hi. The oil service light in red indicates that the vehicle is over due for a vehicle service..OIL SERVICE.. If you don't have it done, it could all go wrong. Have the light reset after Service and then it will monitor for your next service.bye for now.
Feb 19, 2014 | 2002 BMW 3 Series
I have a 97 nissan maxima, it was serviced in february but the service light stays on. why is the service light staying on?
this light may be the check engine light. it's misleading. I've seen two service engine soon lights in cars. one for check engine, one for service. have it checked with a scanner
Jun 17, 2010 | 1997 Nissan Maxima
Engine service light
The engine service light typically means something else is keying the light. Oil changes are ususally not part of the service light causes unless you have oil pressure problems. You should take the car to one of the national parts stores such as Pep Boys or Autozone where they can run a service light diagnostic to isolate the problem. This is generally a free service or low cost service. I would not drive far with the light on so you should take care of it as soon as possible before you have a major problem.
May 31, 2010 | 2000 Pontiac Bonneville
I have ust serviced my 2001 volvo s40 and now the
did the sevice light come on before you serviced it? when you "serviced" it I assume you changed the oil and now need the service light reset.
I bought the 1998 S70. it got time to change the oil. Being how I am I changed the oil myself. I had to call dealership about resetting the service light.
they said $29.96.
I said 29.95?!!! how much if YOU would have changed my oil and reset the light?
they said $29.95.
so I learned you need to access the OBDII to reset the light.after service. hope this helps.
Jun 13, 2009 | 2005 Volvo S40
Engine light on
The service light has nothing to do with the engine light. It can't be trigged by the ECM.
The service light are only trigged by one of 3 counters (time since last service, engine hours or mileage).
The service light are easy to reset if you got a YM1999-2000 car.
1. Put the ignition on to pos.1 and press down the trip reset button on the instrument cluster and keep it depressed.
2. Put the ignition on to pos.2,
3. When the service light starts to flash then release the trip reset button. Now you have reset the service reminder lamp.
You need to read out the DTC's from ECM to be able to fix the check engine light.
Apr 15, 2009 | 1999 Volvo V70
Service light
To reset the MAINT REQ'D light, press and hold the select/reset button on the right side of the instrument panel. Turn the ignition on and hold until the light goes out.
This should get rid of the service light.
Joe.
Jun 29, 2008 | 2001 Honda Accord
Cardiac Science survivalink AED Defibrillator Logo
568 people viewed this question
Top Cardiac Science Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Cardiac Science Medical Expert? Answer questions, earn points and help others
