Question about Car Audio & Video
Meos Mc701b: I need a replacement wiring block that feeds power etc to the back of the stereo, where can I find one?
It is the little block of wire connections that include the power lead etc, that plugs directly into the stereo. I only have the ones that have phono connectors on
  • 78 Answers
SOURCE: Having problems fitting Panasonic CQ-C1323NW car stereo into Ford Fiesta
YOU SHOULD HAVE TWO LEADS IN THE CAR, ONE FOR POWER AND ONE FOR SPEAKERS, YOU WILL NEED A FORD TO ISO ADAPTOR LEAD AND THEN YOU WILL NEED THE LEAD WHICH CONNECTS TO THE PANASONIC RADIO
Posted on Dec 06, 2007
  • 1861 Answers
SOURCE: Need connector block connections for horn wire,relay to button.
The horn switch provides a ground. If you have no voltage at the horn wire, inside the steering whel, I would suspect a bad spiral cable, or clockspring under the steering wheel.
Posted on Mar 04, 2009
SOURCE: No harness plug that goes into the back of my stereo
go to ebay and search this exactly the way it is wrote. ISO Wiring Harness connector/adaptor for KENWOOD 12 Pin
Posted on Mar 22, 2009
  • 35 Answers
SOURCE: How to wire KD-S741R CAR STEREO - WIRE COLOURS ???
older pioneers:
2 x green (1 with black tracer) left rear spkr (black= negative)
2 x white (1 with black tracer) left front speaker
2 x grey (1 with black tracer) right front speaker
2 x purple (1 with black tracer) right rear speaker
Lower connector
1 x red ignition (switched supply)
1 x blue antenna output power (may not be not used)
1 x yellow Illumination (radio button lighting)
1 x orange permanant Battery supply
1 x black vehicle GND
If still not working swap yellow and orange wires! will not cause damage
Posted on Jul 06, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
I have bought a BMW with Meos MC701B installed without a manual. How do I reset the whole thing as does not play any sound when iPhone is connected.
Turn on the head unit. Connect the iPod, then turn on the iPod. The device should then automatically play in IPOD mode.
If you could use the German translation of the manual, then here: http://www.gsl-servicenet.de/jetweb/media/PDF/Bedienungsanleitungen%20AGIS/InDash_German/QSG/MC701B%20german%20qsg.pdf
Nov 29, 2014 | Cell Phones
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
May 20, 2011 | Car Audio & Video
Oldsmobile alternator doesn't work after starting car.. Replaced both alternator and battery atleast 2 times already.. Don't know what the problem is. Checked all fuses, wires, stereo, grounds, etc. Read...
THE RED SMALL POSITIVE BATTERY FEED WIRE COULD BE BROKEN THAT GOES TO BACK OF ALTERNATOR.CHECK TO SEE IF POWER GOING TO THE WIRE.IT NOT POSITIVE BATTERY SMALL FEED CABLE BROKEN.OR YOU HAVE BLOWN FUSE LINK.IF ALL IS GOOD YOU COULD HAVE PCM PROBLEMS YOUR FIELD CONTROL CIRCUIT PART OF THE PCM CIRCUIT.HAVE VECHICLE SCANNED TO LOOK FOR ALTERNATOR PCM FAULT. AFTER YOU INSTALL NEW ALTERNATOR DONT CRANK THE CAR UNTIL YOU GET A SCANNER AND ERASE TROUBLE CODE FIRST BECAUSE THE PCM THINK OLD ALTERNATOR STILL IN VECHICLE AND WILL CAUSE CHARGING PROBLEMS.
Dec 29, 2010 | 2003 Oldsmobile Alero
Installed Meos mc701b with navme 120gps nav system. All fine except that the sound on nav instructions is very low and see no means of resetting it. Any solutions? Seems a common problem
This is simple - go to the NAVI screen itself via the menu - turn the volume up using the volume up key.
Return to the radio and now hold down the menu key - you will go back to the sat nav screen with the radio playing in the background - when you now get voice prompts they will be louder than before!
Nov 10, 2010 | Car Audio & Video
I have a meos mc701b coupled to a meos navme120 and i cant get the satnav to work it just keeps flashing up the same message "no signal" any ideas
Go to GPS hardware and select "locate" then try the different port options - it will be on one of them - problem solved.
Jun 27, 2010 | Car Audio & Video
Hi-changed over my car stereo out of my hyundai coupe 04 today but now the new stereo will not switch on automatically when power to unit-resulting in cd etc starting from begining again-i removed a...
you more than likely have the red/yellow wire (coming out from the back of the radio) reversed. the orange wire is usually for the dimmer feature and is not necessary to hook up. The red wire needs to be hooked to an accessory wire (i.e. send power when you turn the car on and goes to ground when the cars off) and the yellow wires needs a constant power source (i.e. always on from the battery) the yellow wire lets the radio retain memory.
May 01, 2010 | Car Audio & Video
How to connect hand brake cable on meos MC701B
if you can get to the hand brake, there is usually 1 wire coming off of it at the base, you will want to test it to make sure it is sending the ground pulse, just splice it into that wire. If you want to save yourself the headache, just put a switch to a ground (-) and hook that up to the handbrake wire (coming from the unit). It will do the exact same thing, but with a lot less work.
Apr 29, 2010 | Car Audio & Video
When I transmit it feeds through my stereo
if you are using a kicker (amplifier) alot of times they will cause it make sure your wires dont cross any of your radio wires under the dash
you can buy noise filters for stereos they are generally used for car amps but i have heard of people using them because of cbs too
May 02, 2009 | Connex 3300 240-Channels Base CB Radio
Radio and clock doesn't work after replacing blower motor switch
You also have to remember that the stereo has a fuse down by the driver's side door in the panel. I mention that because you didn't so maybe you over looked it? As for the other person having the clock reset AND having little power to windows, check the power comming from the alternator and the battery with a multimeter. Make sure you know what you are doing. It should read anywhere from 11-14.4 volts. Anything less, either of them are going bad. Also, try removing the radio and locate the "battery feed" wire. It;s normally yellow, but I think it's a different color in the Rodeo/Passports. Anyway, just look it up. With the car off, take the multimeter and the positive in the feed wire and touch the negative to a ground (mostly any metal will do). If you are not getting power even with the car off, you have a lose/broken connection somewhere. That wire supplies power to the radio to hold the info while the car is off, such as memory channels/clock/etc. For both of you: also check the power comming from the power wires to the radio, make sure they are around 12-14.4 volts too, then work back from there. If you are getting power, then the radio is dead. Hope this helps.
Jun 26, 2008 | 2000 Ford Ranger SuperCab
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
