Frigidaire Portable Air Conditioner
Problem for Frigidaire (FAP094P1Z) Portable Air Conditioner
My portable frigidaire air conditioner bucket light on
By desmondd1254 on Jun 08, 2009
whhere can you find the bucket on frigidaire FAP 094PIZ2
to empty it on the unit
Solution #1
posted on Aug 05, 2009
Not Rated)
la_matt_nyc
Rank: Apprentice
Rating: 0%, 0 votes
The actual bucket is located inside the machine at the bottom.  To access it, you must unscrew all of the screws and take the front panel off.  You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine.  Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Portable Air
Questions and Unsolved Problems for Frigidaire Portable Air
Do you recommend Frigidaire (FAP094P1Z) Portable Air Conditioner?
Answer
Answer
Our Frigidaire FAP094P122 is leaking. At first I traced it to a pinch in the black drain hose. By... (More)
Answer
The water reservoir fills up and the pump no longer drains it.  The problem just began and... (More)
Answer
Hello there. I would like to seek views on this really cool product from Plasma Cool portable air... (More)
Answer
I just bought the Frigidaire Portable Air Conditioner and it is making a very loud sound. There is... (More)
Answer
the air conditioner freeze then the water leaks out on the floor it does not drain through the hose
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
