Question about Bosch Coffee Makers & Espresso Machines
Bosch built in coffee maker service - Bosch Coffee Makers & Espresso Machines
3 Suggested Answers
  • 7 Answers
SOURCE: Bosch Benvenuto TKN68E75 Coffee Maker
On the bottom of the sliding spout assembly is a little tab (remove tray and look w/mirror). Once you depress that with a knife/fingernail/screwdriver, you can pry the cover of that assembly toward you on the bottom. Insert a screwdriver in the resulting slot on the side and carefully slide it up; the curved plastic cover with "BOSCH" on it will pop off. Don't worry, it's pretty flexible PVC.
Now pull on another (newly visible) tab on the bottom of the assembly (use mirror again) to disengage the entire spout mechanism (two black cylinders) which will then hang toward you by the coffee tube only. Carefully disconnect the coffee tube. Now you can wash them out (I do that every 6 months or so).
Best results: Hold one tube and the middle drainhole shut with your fingers and blow water hard into the outflow side of the other one (over the sink, of course). Repeat on other side. Soak unit in hot water w/soap, clean w/high flow, dry. Your view into the unit from the bottom (where the coffee normally comes out) should be unobstructed except for the PVC cross inside the tube.
Everything snaps back together very easily. The hardest part is connecting the coffee tube again, especially if you have big hands...
While you're at it, open the side panel below the bypass doser. On the brew group you can see three little plastic covers that, once pried off with a knife, reveal three 1/4 turn screws marked with an open and closed key symbol. Opening them will enable you to slide the brew group out and give it a good cleaning.
Take a vacuum cleaner with the narrowest attachment and vacuum all the loose coffee grounds out of the machine. Clean the inside as much as you can. Do not reassemble until the brew group is dry, otherwise the wet spots become caked with coffee.
Unscrew the steaming wand by loosening with a coin or knife on the bottom. It disassembles into a rubber holder, the metal wand, and the plastic frothing piece. Soak all three in a glass of hot water with soap. On the frothing piece there are two notches as well as a tiny hole that I usually have to clear with a knife tip. Insert a soapy Q-tip up into the pipe on the machine and "roto-root" it. Repeat with clean/wet Q-tip. If the outside of that pipe is dirty, tie a hot wet paper tower to it for 1/2 hr to soak it off. A Scotchbrite pad or steel wool will do the rest. If you maintain it this way every two weeks or so, it will never get caked up and you'll always have great foam.
Bosch factory support and local support is questionable, so I clean mine every 6 months or so, now that I know how to do it...
Posted on Sep 11, 2009
Testimonial: "Thanks a million for sparing your time and knowledge, your very detailed help has been invaluable"
  • 11800 Answers
SOURCE: Bosch Benvenuto built in Coffee
The quality of the coffee depends on the amount of actual coffee used - if it's too weak then not enough coffee is delivered to the filter by the dispenser. You will have to take the dispenser apart to see what's preventing it from doing its job - most likely it's clogged and in need of a serious cleaning.
Posted on Apr 03, 2011
My Bosch coffee maker tank is full but I am prompted to refill water.
Hi!
I'm adding a link to manuals to Bosch coffee machines.
Please check, hope you can find the manual to your devices and it will help you
https://manualsbrain.com/en/brands/bosch/coffee-makers
Sep 29, 2017 | Bosch Coffee Makers & Espresso Machines
How do I replace the service t disc for my mother-in-laws Bosch Tassimo T 20 Coffee Maker?
Ask your doctor to write you a prescription for one. Be sure to tell him what color you want.
Sep 09, 2016 | Bosch Tassimo T20 Single Serve Brewer,...
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Want to clean the grinder part of my built in miele coffee maker.
Very Carefully with the power plug pulled out of the wall.
If you do not have the manual, go on line and have customer service send you a detailed instruction manual or have a technician take you through the process.
Mar 25, 2014 | Miele CVA4070 Coffee Maker
Bosch TKA 9110 UC Porsche Designer Series Coffeemaker my Bosch coffee maker in transit....I lost the little round ball that sits in between the coffee pot and filter section. How do i replace that...
Here is the link for the Bosch service locator. Enter your zip code (I assume that you are from USA) and you will see the nearest servicer for Bosch. From there you can get the address or phone number to contact them and order a new replacement for the missing part.
Hope that helps. Can't help you more at the moment, because you did not give sufficient information about where you live and where did you buy it.
Mar 06, 2011 | Bosch TKA 9110 Coffee Maker
Trying to locate a store where to find cleaning tablets for Bosch Benvenuto B30
You did not state geographic area. The part number is 310575
You can order them on line here: (10 pack $12.95)
http://www.partstore.com/Part/Bosch/Bosch/TKA9110UC01FD8110/Bosch/Bosch/310575/New.aspx
also here:
http://www.apwagner.com/index.php?main_page=product_info&products_id=654260 ($12.90)
There is a Descaling Maintence Pack 311196 That I would recommend everyone with a good coffee maker should use:
http://www.bosch-eshop.com/eshop/bosch/gb/article311196.htm
This is only on line sources.
Thanks for choosing FixYa,
Kelly
Dec 10, 2010 | Bosch Benvenuto B30 Espresso/Coffee Maker
Coffee Makers & Espresso Machines Logo
22 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
