Question about Jenn-Air JS48PPFXDA 48 inch Built-In Side-By-Side Refrigerator
Jenn air freezer forms ice on back wall - Jenn-Air JS48PPFXDA 48 inch Built-In Side-By-Side Refrigerator
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
SOURCE: Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Posted on Oct 03, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
Ice maker leaking out the bottom and refreezing ice cubes to a big glob
are the cubes coming out of the unit? Sounds like the heating element is not activating, to release the cubes prior to refilling. Check electrical connections at the rear of the unit against the freezer wall that they are together. If ok then defrosting element may be defective, Replace unit.
Aug 27, 2013 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air refrigerator, top freezer, older model, frost-free. Ice has started forming on the "ledge" at the back wall where the lowest shelf rests. Then the ice melts and water pools at the...
There is probably a little sediment in the ice maker shut off valve. It's electrically operated whenever the icemaker starts a new batch.
You can try cleaning the valve, but it's typically not worth the trouble. I'd just install a new one. It's easy, typically just a couple screws, an electrical connection and the water connection. To prevent it from happening again, add an in-line filter BEFORE the ice maker.
Jan 31, 2011 | Refrigerators
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
Freezer is not cooling at top - ice melted -not cooling on top of refrigerator - bottom of refrigerator is frozen
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
Feb 12, 2010 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrig model # JCD2389GES is not cooling on the refrigerator side but is fine on the freezer side.I changed the thermostat and was good for 40 days,then the nightmare started again.
the problem is in your freezer
you need to opaen the wall inside the freezer and see if there is ice build up on the coil.
if it is frozen heard you need new thermostat or heating element. check it first and let me know what you see.
open the back wall (the bottom one)
Feb 07, 2010 | Jenn-Air JCD2389G Side by Side...
Water leaks from freezer side, ice forms at bottom, ice maker works
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
Good luck... 911servicetoday . com
Apr 29, 2009 | Jenn-Air JCD2295HES Side by Side...
Ice forming on the inside of the freezer
freezer fan light maybe staying on or freezer door is not properly close
Mar 31, 2009 | Kenmore 55692 / 55694 Side by Side...
Water leaking out from the inside bottom Jenn Air JRSD245L
It sounds from what you described is a clogged drain line pull the bottom drawer out and look at the bottom of the back wall. see if the drain is backed up with ice if so use the back end of a rubber handle screwdriver and lightly tap the ice until it breaks up clean up the best you can around the drain and pour some hot soapy water down until to you hear it going into the drain pan.. a cup will do....>>the water comes each time the unit goes into defrost as the heaters melt the frost build up on the evaprator it melts and is suppose to go down the drain but if it is blocked then it forms at the bottom of the freezer floor..let me know if you still need the wiring diagram I can email it to you. Hope this fixes YA !
Feb 22, 2008 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Refrigerator
If the ice build up is only on the back panel of the freezer then you have a defrost problem. Most likely a defrost thermostat or control board/timer. If frost build up is around the walls of the freezer then warm air is getting into the freezer. Most likely cause of this would be gaps in or torn door gasket or door alignment. In some cases the door was left cracked open. If gasket and door alignment is ok remove the frost and see if it comes back.
Oct 05, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Refrigerators Logo
21 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
