Question about Stihl HT101 Pole pruner
Greasing the drive shaft
Do I have to grease the drive shaft, I don't find any grease fittings?
  • Stihl Master
  • 1,807 Answers
Yes grease the drive shafts. there is no greasing point, you have to remove the attachment and remove the inner shafts. Heres the manual, hope it helps
http://www.mediafire.com/view/a33fr2038d5u1cr
Posted on Mar 07, 2015
Where and how many grease fittings are there?
Rudy, From the factory, the Buick LaCrosse probably had no grease fittings on it. Over time parts may have been changed, the new parts may or may not of had grease fittings. Grease fittings for steering could be found on lower ball joints and outer tie rod ends if they had been replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Stop Your Car From Squeaking
Steering May Develop Clunk Noise From Upper Intermediate Steering Shaft...
The Intermediate Shaft and Steering Issues
Chassis greasing tie rods ball joints properly JOETHEAUTOGUY
Apr 17, 2016 | 2006 Buick LaCrosse
Lube drive shaft
Look for the grease fitting,will need a grease gun with a flex hose.Here's a link with some grease fittings. picture of drive shaft nissan pathfinder Bing
Feb 03, 2014 | Nissan Pathfinder Cars & Trucks
Grease front axle u joints
I'm going to guess here & say you don't have any
My 04 Lincoln Ls has non & a cousins 05 expedition
has none that I have seen so far,unless you replace the
very common bottom ball joint failure issues ,then you get
grease fittings on Moog Parts
I would check the drive shafts though for fittings, they be
recessed & hard to see & need a grease gun adapter
Dec 12, 2012 | 2004 Ford Expedition
Does a 201 pontiac sunfire have grease fittings?
alot of these cars don`t have grease fittings from the factory as they are considered lifetime(permanent) greased components.however this doesn`t always work.if the components have at one time been replaced then they will have a grease fitting in them that needs to be greased.
Jun 29, 2011 | 2001 Pontiac Sunfire
Can I obtain a diagram that defines the location of the 11 (?) frontend greae zerks for a 2000 Bravada? Jiffy Lube says none of mine will take grease and need to be replaced!
Upper and lower ball joints -4
Both ends of tie rods --4
Ider arm--2
Front Drive Shaft--1
If you just get under the truck you will see them
They have been on that type of suspension for
60 years
I would bet you have one bad fitting at most
I don't know of a single person who would ever
recommend any fast service oil change places
They are a horror story you want to avoid.
Buy a top quality Lincoln Grease Gun with a flex
hose and the proper grease for a GM Vehicle
and do you own
I believe Valvoline #615 is what you want.
Apr 25, 2011 | Oldsmobile Bravada Cars & Trucks
When replacing a u-joint should the grease fitting face forward or back. I'm working on the drive shaft of a 1974 Ford Maverick.
The grease fitting should face the rear if replacing the trans. u-joint and forward if replacing the diff. u-joint.
Apr 17, 2011 | 1965 Ford Mustang
1986 chevy s10 trying to remove center bearing on
theres a collar on the youk.remove it and tap it out its splits the tow pieces of drive shaft.use alot of pb blaster and make sure you grease the youk theres a grease fitting there
Mar 27, 2010 | 1998 Chevrolet S-10 Pickup
PROBLEMS with drive shaft thi is the 3rd time i have to rebuild the drive shaft is a 2 part drive shaft 1time rebuild the front part and 2 times the rear part any advise why is this happening
The only thing that should kill the shaft that many times is having it out of balance. Eventually a two-piece shaft will fail but it's usually after a couple hundred thousand miles. To have three of them fail seems to suggest that when they've been rebuilt, they haven't been balanced properly afterward. Find a truckstop and have their service guys rebuild it if there's no dedicated driveshaft shop near you. Truck guys will have the knowledge and equipment to properly reassemble and balance the shaft.
Dec 03, 2009 | 2002 Chevrolet S-10
How do I grease the u-joints on the back of the drive shaft? on a 2000 toyota tacoma prerunner 2.7 liter
Grease gun with an adapter that allows you to get into a tighter space. Any auto parts place will sell these. Note, that a lot of replacement u-joints have grease fittings, as some stock ones don't require grease.
Nov 11, 2009 | 2000 Toyota Tacoma PreRunner
Stihl HT101 Pole pruner Logo
236 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
