Question about HP LaserJet M1212nf MFP Printer
Will not print from computer sscreen says supply error
How to place icons on desktop home sscreen windows 10
Click on Start, locate desired program. Left click and drag to desktop.
Mar 05, 2017 | Computers & Internet
Printer not printing from computer, copies OK no error signal just does not print. computer Toshiba laptop Satelitte
Turn printer off and then unplug it. Reboot computer. Plug in printer and turn it on. Go to printers, and see if it shows as default. Try printing a test page. Good luck.
Feb 22, 2017 | Toshiba Office Equipment & Supplies
I have a hp color laserjet 2820, it says "replace supplies" and "device busy" . It was working fine yesterday and now won't print.
The replace supplies means that something has either reached end of life or has failed and needs to be replaced. Device busy usually indicates that there is a print job queued in the printer that needs to print, but the supplies out is stopping that from happening. Clearing the print queue on your computer and then restarting your printer might clear the device busy error, but the supplies error will likely require replacement of something.
May 01, 2011 | HP LaserJet 2820 Printer
My battery backup failed. I plugged my computer and SyncMaster 932B monitor into a power bar. The computer is on and working, my monitor is not. If I turn it off and then on again I will see my screen...
chb3113, You will need to do the Flashlight test when monitor goes to black screen! Tell me what you see or don't see by holding a bright flashlight 1 inch from sscreen where you know something should be!!! If you see the icons or win-start button then switch-mode-supply is in partial shutdown mode. See nothing, then SMPS in full shutdown mode. Sounds like failed capacitors on SMPS printed circuit board or problem with the cold cathode fluorescent lamp electronic ballast circuit which lights-up your lamps. If not willing to do the research and the repair work, then just trade-in for new unit. Do some reading in my and other CCFL back-lit lcd monitor tech's fixya profiles to see if DIY will work for you. Follow links you find there. "budmrtn" "buddymc" "12fixlouie" (me) are just some of the files you should read and also visit YOUTUBE for repair video clips of other owners who repair their units for less than $10 in parts. Reply back here to this response with comment and rate this response if you feel it was helpful after doing your reading and research. 12fixlouie
Aug 11, 2010 | Samsung SyncMaster 932B LCD Monitor
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
I can not get my nx415 to print over my home
Calvin. This setup is so old tech !
check workgroup names are the same on both computers
better setup
If it is an ethernet network
Get a usb to Ethernet print server and you can print to the printer without having to keep a receiving computer turned on .
https://www.mwave.com.au/wired-networking/print-servers-wired
Jan 25, 2018 | Epson Office Equipment & Supplies
The camera goes on but lens error appears on sscreen and the lens does not protrude out. shutter is half open
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Nov 23, 2008 | Nikon Cameras
No screen
Does the power light come on? If not it could be a power supply or adapter. If you have a power light, hook up the PC to an external monitor(if available) and if that works, it would be either your screen or video adapter.
Dec 06, 2007 | Acer Aspire 3000 Notebook
HP LaserJet M1212nf MFP Printer Logo
12 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
