Question about Kenmore Elite Oasis 27052 Top Load Washer
Replace pump on kenmore model 4564291
How to remove the pump
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: our kenmore 110-4564291 machine (Canadian model
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
I have a kenmore front loader recently it has decided to stop spinning and retain water. Help?
Regardless of model, this is probably a drain pump problem. With many Kenmore washers, there is a pump trap that can become plugged. Remove the washer's bottom front panel, if there is a white drain pump casing, turn out the pump trap counter-clockwise, making sure to have a bucket to catch the water. Check and clean the trap, and try to spin the pump impeller, if the pump impeller is stuck, something may actually be stuck in the impeller. If the impeller feels wobbly, you will want to just replace the drain pump entirely. Depending on the model, there may just be a hose connecting directly to the pump, with no trap available, just pull the hose off and check for an item plugging the pump. With any model, there will be WATER that will POUR out. Be prepared.
Mar 17, 2011 | Kenmore Washing Machines
Water leaks under the washing machine Kenmore top loadin washer, model 110-234642300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet and gain access to the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?
newsPath=16&newsdesk_id=134&osCsid=b547cd9bb24b4ffaef51e860554a9cb0
Check the areas for the motor and pump and the Agitator Basket and Tub.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Jan 11, 2010 | Kenmore Washing Machines
My kenmore top loading washing machine won't spin
Once you remove the cabinet,remove the water pump and check it for a garment or lint. Clean or replace the water pump and reinstall it.
Oct 31, 2009 | Kenmore Washing Machines
70 Series Kenmore washer pouring water underneath washer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Our kenmore 110-4564291 machine (Canadian model number) will not go past the wash cycle. It stops and won't proceed to spin or rinse. It's 10 years old. Is it worth repairing?
Jun 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at www.timerking.com for 9.99 or from sears. Hope this helps!
Feb 02, 2009 | Kenmore 24902 Top Load Washer
Kenmore washer model 70 leaking
More than likely the pump. Very easy fix. To keep from being redundant I prepared a page on direct drive coupling removal and replacement. The pump must be removed to fix this item therefore it pertains to your problem. Plus you can watch for leaks better with the cabinet removed. To read click HERE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
