Question about Kocaso Tablets & eReaders
Will not turn on
When the tablet is plugged into the outlet there are not lights or signs that it is being charged the screen just stays blank
  • Kocaso Master
  • 2,219 Answers
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Posted on Feb 22, 2015
5 Suggested Answers
SOURCE: Blank screen on laptop
Maybe the OS is corrupted, try to reinstall the OS
Posted on Jun 24, 2009
gopakumarg43
  • 75452 Answers
SOURCE: I charged my tablet up but it won't stay on. I do't use it a lot,
Sounds like battery to your tab is weak. [Charge holding problem], Check it with an other new battery. Electro help
Posted on Dec 08, 2014
  • 9 Answers
SOURCE: my son got tablet for Christmas t took initial charge. worked fine this morning now it wont turn on or charge. any suggestions?
Is the green charging light displaying on the side of the tablet and/or does the screen indicate that it's taking a charge?
When you hold down the power button for 30 seconds or more, does the screen indicate anything? Charging? Battery low? Charged?
If it's new (and your son doesn't have any/much personal files on the device it's probably less headache to just return it to the store and get a replacement.
Posted on Dec 25, 2014
lawrencem420
  • 9 Answers
SOURCE: Battery will charge to 100% only 50%
Its probably because of your tablets power source. If you have used your tablet very often then it will begin to cause the battery to drain more quickly and it will also not fully charge. It could also be a problem with your charger. There could be a short in it or something else that would cause it to stop charging the device at a certain point. The tablet isn't powered by a removable battery so don't try to open up the back and tear out any circuit that you think is the battery as this may cause even more damage to your tablet. If you have a warranty on the device then try taking it to the store you bought it from and see if they can help, but if you don't then be prepared to spend some cash. You could also take it to a tech store (if you know of one) and maybe they could run a diagnostic on the tablet to see what's wrong. If you're trying to charge your tablet while its turned on it could also be the amount of apps that you have installed on your device. Apps can actually cause put a strain on the battery and cause it to preform poorly. Try to avoid large apps (apps that take up a lot of space) because they can actually cause the device to run slower and it will also force more power to be drained from the battery which in turn will keep the battery from charging fully while its on. Try either one to see which one works for your device.
Posted on Jan 07, 2015
The charging light will come on, but when I turn on the kindle the green light comes on for a second then goes off and the screen stays blank
the battery has died . take it to a computer shop and see if they can replace the internal battery
Dec 05, 2015 | Tablets & eReaders
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
Jan 01, 2015 | Tablets & eReaders
Screen is dark orange light on. plugged into power but nothing is on the screen
First - let it charge for an hour before continuing. Some tablets require that you hold the "On" button for 2 seconds to turn it on.
Dec 25, 2014 | Tablets & eReaders
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
My tablet M9200 will not turn on
Feb 10, 2014 | Kocaso M1050
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
My amazon kindle is unreponstive.how can I fix it, has blank screen will not let me connect to internet
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device.
Feb 23, 2011 | Amazon Kindle Wireless Reading Device
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
Kindle 3g screen is blank can get it back on
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 17, 2011 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
27 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
David Payne
David Payne
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
