Question about HP LaserJet 4250dtn Printer
HP LJ 4250dtn fuser error 50.2
Fuser error 50.2
2 Suggested Answers
  • 26 Answers
SOURCE: Error 60 02 on a HP LJ 4250DTN
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Posted on Jan 11, 2008
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Why we get 50.2 error plz heip me
8568e469-5614-4f4b-85d3-8836768de9b4.jpgThat error indicates a problem with the fuser in the printer. You will need to replace the fuser assembly to correct the error. Here is the information from the service manual regarding that error.
Aug 13, 2013 | HP LaserJet 4250dtn Printer
50 fuser error in hp lesarjet printer
An error 50 on most HP Laserjet printer indicates the fuser has a problem. Most common problem is the heat lamp burned oou. The lamp is not a replaceable item unless you re a top notch technician. The fusing assembly however is usually a relatively easy replacement requireing only twisting of a couple of latches or removal of a couple of phillips screws.
The part # for the fusing asm for the HP LJ 3030 is RM1-0865-000CN.
These can readily be found online for anywheres from $120 to $250.
Dec 18, 2010 | HP LaserJet 3030 All-In-One Printer
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
I have an hp 4250dtn and the fuser rollers at the initial point don't turn, also I am getting paper jams on top by the cartridge, I noticed that the paper is not fusing with the ink, but I am not sure...
The fuser and swing gear asm (the swing gears drive the fuser) probably needs to be replaced. I rarely see the fuser drive motor cause this kind of problem. Are you hearing any noise coming from the back?
Nov 03, 2009 | HP LaserJet 4250dtn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Error code- 50 service
Hi Sheila,
The following page gives the reason http://www.all-laser.com/cgi-bin/webc.cgi/error50.html
Seems the printer needs something called a fuser. There is a link to maintenance packs including the fuser or just the fuser alone.
Apr 27, 2009 | HP Office Equipment & Supplies
HP LaserJet 4250dtn Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
