Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Spot bot poor suction - Bissell SpotBot Robotic Wet/Dry Vacuum
3 Suggested Answers
  • 5370 Answers
SOURCE: model 7887 spot bot will
Is the motor running in the unit, when you start.If not, then motor has to be checked.Sometimes the motor gets dirty and it gets blocked by dust.Getting the motor cleaned, helps.But if its still not turning ON.Then motor is the issue it has to be checked and replaced.Check out.Keep updated.Thanks.Helpmech.
Posted on Apr 07, 2011
bissellcs508
  • 315 Answers
Life Inspired Cleaning Innovations
    Verified Fixya Pro
    SOURCE: Automatic Clean on Spot Bot 1200 dosent work
    Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
    To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
    Posted on Oct 22, 2012
    Spot Bot wont spray
    Not having the machine spray when you need it is frustrating.
    Here's a quick link to troubleshooting steps to assist you.
    http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
    Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
    Tip
    How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
    Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
    This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
    If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
    Here's the video showing how to replace the hose:
    Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
    Thanks so much,
    Chris JonesGoVacuum
    on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
    Spot Bot leaves mold rings
    Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
    You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
    Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
    SPOT BOT NO SUCTION
    Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
    http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
    Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
    Clean bissell spot bot brush
    NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
    Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
    I need an instruction manual or booklet
    I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
    http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
    May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
    Need a Bissell Spot Bot Manual
    You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
    May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
    Leaving bigger dirtier wet spots after cleaning
    Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
    Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
    Power head on epic 6500 does not work, is there a belt?
    This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
    Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
    Poor suction caused by a blocked or partially blocked pipe.
    An obstruction that is tactchin the beater or the turbo fan.
    Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
    Jan 18, 2009 | Electrolux Epic 6500 Vacuum
    I HAVE A BISSEL SPOT BOT THAT WON'T **** UP THE DIRTY WATER.I TRIED TO TAKE IT APART TO CLEAN IT, BUT DIDN'T GET VERY FAR. ANY SUGWSTION? THANKS, ...
    No Suction
    Possible Causes Remedies
    Tank is full. Empty tank.
    Dirty/Collection tank latch is not down. Push latch down, securely
    into place.
    Black Valve on the Dirty/Collection Tank is missing. Replace Black Valve into Dirty/ Collection tank.
    Usually there is a seal out of place, or a filter is clogged, so you lose suction.
    Apr 30, 2008 | Vacuums
    Bissell SpotBot Robotic Wet/Dry Vacuum Logo
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
