Question about Samsung 26 Cu. Ft. Side-by-Side Refrigerator, RS267LA
Samsung RS267LBBP Refridgerator Won't Make Whole Cube of Ice
Ice maker only spits out busted up cubes with maybe one or two whole cubes. It is set to "cubed" and temperature is set to -6F. It also sounds like it struggles (with lots of pops/snaps) to eject ice from the tray into the bucket.
bbtoast
  • 319 Answers
SOURCE: Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Posted on Jan 01, 2008
VOTIT
  • 2071 Answers
SOURCE: Samsung RS2555sl\xaa Refrigerator. Ice
Go to site for spare parts:
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jul 07, 2008
rickzilla
  • 706 Answers
SOURCE: ice cube tray not releasing cubes
The ice maker system is pretty simple.. A motor rotates with a gear reduction system and as it rotates... a switch is tripped when the motor reaches a certain point on its rotation... that switch lets water in for a prescribed period of time ( normally that is adjustable) and then as the motor rotates some more.. the ice tray has had adequate time for that ice to freeze and is positioned for it to be released,..at that time.. a small heating element is energized to release those ice cubes and the cubes fall from the tray into the bucket.. Chances are your heater is not working, unplugged or defective.. I would start by thawing everything out and getting the system free of any and all ice.. If after you've cleaned it all up.. and it still fails to release ice..you could be over-filling your tray and that freezes .. which in turn causes the system to fail too..You may need to adjust the fill level by throttle back on the water or if your system has a fill level control.. adjust that.. but first things first.. get the system back to a known good state.. ( meaning free from all ice ) so that you can monitor its performance,. Hope that helps...
Posted on Aug 16, 2008
  • 219 Answers
SOURCE: My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Posted on Mar 19, 2009
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice maker crushes ice will not extrude cube cubes
Your ice bin is out of alignment. Pull the ice bin all the way out and re-insert it and make sure it locks in place. When you re-insert the bin,look underneath the bin. You will see a metal rod. It must go INSIDE the yoke at the rear of the freezer, NOT under the yoke and NOT over the yoke. In the yoke.
This is a common problem and will happen again. The ice bin has a way of dislodging itself. If the rod is not in the correct position you get crushed ice regardless of the setting.
Sep 29, 2009 | Frigidaire Refrigerators
My Samsung RS267LBBP refrigerator low ice
you could have a faulty ice maker try to reset it by pushing the reset button if this does no good have the ice maker replaced are you cubes normal size
Sep 16, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Jun 07, 2009 | Refrigerators
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Feb 08, 2009 | Samsung RS2630SH Side by Side Refrigerator
My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Oct 04, 2008 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
