Question about Konica Minolta Bizhub c203 Copier
How to remove bizhub 750 drum unit - Konica Minolta Bizhub c203 Copier
  • Konica Minolta Master
  • 6,161 Answers
Try this site for the service manual, though i recommend a tech do that so you dont damage the drum associsted sensors
Service manuals electronic components datasheets and equipment schematics...
Posted on Jan 23, 2016
4 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: How do you remove the drum unit on a bizhub C203
Just follow the procedure when you open the front cover. The Drum and Developer units are one unit. Press down to release the unlock lever of the image unit to be replaced. Then pull out the image/developer unit Black. Upper units are toner cart.
Posted on Apr 14, 2010
resonatom
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
Posted on Mar 09, 2012
bendarden
  • 984 Answers
SOURCE: install imaging drum Bizhub c352
The best way to solve your problem is to download the official Konica troubleshooting solution manual. It will tell you how to pinpoint and fix every problem reported to Konica. CLICK HERE
Posted on Jun 08, 2012
What is error code c-2401?
Clean the drum sensor that monitors the drum, and the surrounding area. also has the developer and drum been replaced.to clean the drum sensor the drum must be removed. do not use a vacuum cleaner as static electiricty can destroy the senor, use a clean brush. located under the drum to the rear has a white cover over it, the clear sensor in the middle is for paper jams.
Apr 22, 2016 | Konica Minolta bizhub 750
PROCEDURE CHANGE DEVELOPER KONICA BIZHUB 600
First clear the developer counter in service mode.
then remove the drum cart. remove developing unit. remove old developer. then run Auto max density. If you don't and make a copy or print you will have to replace the developer again
. recommend cleaning all toner around the drum and drum sensors requires removing drum be careful a nick on the drum will show up on all copies/prints
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
Bizhub minolta 600 and 750
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
try this site for developer and drum as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 21, 2014 | Konica Minolta Bizhub C454 Color Copier
Konica minolta bizhub press 1250 p c-2101
Charge cleaning assy. error. There is a very fine gold plated wire that is above the drum on the drum cart. Must be remove to be seen. Well there is cleaning device for that wire. you may hear it some time when you turn on the machine. Well its stuck or the motor (bad/Stuck) or sensor that tells the machine the cleaner is back home mite be dirty/Toner. Remove the drum cart and check it out. There is also the same system for the transfer/separation wires that are below the drum which the paper goes over as the drum transfers the image to the paper.
Oct 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
Konica Minolta Bizhub 600 c-2101 code
C - 2101 The lock signal of the charging cleaning motor(mounted on the charge corona assembly) is not detected when a specified period of time elapses after is starts the backward operation from rear to front.
Remove the drum unit and remove the charge corona and rotate manually the cleaning pad,eventualy remove the cleaning motor and verify the gears.
If not reseting to Open /close the frontal door,try reset:
Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message ,release the Utility key and touch the message,then turn OFF the copier.Wait 1 minutes and turn ON.GOOD LUCK!
Mar 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
I have a konica Minolta bizhub 750 and its giving me error code c2401 what may be the problem
Sir/Mam, The Erase lamp is disconnected. have you had anyone recently replace the drum or developer? if so the erase lamp connection is not seated properly or you do have a bad erase lamp. You will have to remove the drum cartridge open front door life up small pipe unscrew the main nut hold nut unscrew (When screwing back in do not allow the nut to turn to the right) Any way once the cartridge is removed check two connections above the drum to the rear to small connectors (BE CAREFUL DO NOT SCRATCH OR NICK THE DRUM DO NOT EXPOSE TO SUNLIGHT) ensure the two connectors are secured! Re-install. if the code comes back you mite have a bad Erase Lamp. Contact a Technician!
Feb 05, 2013 | Konica Minolta Developer 02xk Dv710 for...
Where is the pc drum located on a bizhub 222
Open the side door and see a colored cylinder, that is the drum, but removing it will not be easy, you have to remove the image unit and then separate it into two parts: developer unit and clean unit, already once separated the unit will be easierremove the drum.
Note, remove the module from the front image
Apr 25, 2012 | Konica Minolta Bizhub 222 Black and White...
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
Konica Minolta Bizhub c203 Copier Logo
48 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
