Question about Refrigerators
E 5 error code haier beeping noise
When I plug in the refrigerator it sounds good. but 15 minute later it make a beeping noise and the control settings on top are flashing. How do I fix it.
SOURCE: 3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
Posted on Feb 05, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchenaid built in refrigerator controls are beeping
Sounds like a water flow issue. Check to make sure your manifold is getting proper water flow.
Posted on Feb 14, 2009
davidpsr
  • 222 Answers
SOURCE: intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Posted on Jun 27, 2009
  • 2418 Answers
SOURCE: Haier HRF10 Moaning sound coming from Condenser fan.
It is the fan, Its time for a new one or try to oil her.
Posted on Jun 29, 2009
rylee_smith
  • 8619 Answers
SOURCE: Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jul 01, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire FRA186MT2 beeping noise
sounds like you have a problem with the temperature probe - system defaults from temp to a time cycle if the probe fails
Nov 28, 2013 | Refrigerators
My ac is showing an E1 code. what can be done to solve this problem?
Unfortunately, there's not much you can do. The E1 error code indicates a sensor shutdown. However, you can try turning the unit OFF & unplug it for 15 minute. Then plug it back in and turn it ON. If the electronics reset and reverted back to the original factory setting, you can set the controls as you like.
If you continue to get the E1 error code,, contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My whirlpool ED5FHEX all of a sudden sounds like a motor reving from below in the back. It gets pretty loud. Sometimes I unplug the refrigerator and wait several minutes before plugging it back in and the...
If the shock absorbers under the compressor are damaged or loose there can be a lot of different noises but I have never heard it referred to as a motor racing.
A motor racing sound would be more like a fan motor going berserk and not keeping a constant speed. Since the compressor fan is located in the area of the sound you might want to take a look at it and see if it is keeping a constant speed.
Aug 16, 2011 | Whirlpool ED5FHEXMQ Side by Side...
Dehumidifier not turning on showing an e2 code
Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Haier 45-Pint Dehumidifier
Jun 28, 2009 | Haier HRF10 Top Freezer Refrigerator
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Haier air conditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=1797 Hope this helps! ;)
Sep 03, 2006 | Haier ESA308 Air Conditioner
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
