Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby G series won't turn on
Checked beater bar, and both external switches
  • Kirby Master
  • 1,926 Answers
COntrol of the connection of the bag at the bottom of the machine that must be against the housing rotated are, there is also a microswitch used for safety, but there is a second micro switch that sits in front of the vacuum cleaner housing near the air intake as a push button which is operated next near to the hoseconnection by a pin.
Posted on Oct 19, 2015
3 Suggested Answers
RockyNR1
  • 324 Answers
SOURCE: The beater bar on my Kirby Generation 3 does not
First - make sure that you are installing it right - see online manual HERE . If you still can not get it working right - issue new ticket and explain in more detail what is wrong there...
Good Luck
Posted on Mar 03, 2009
VacuumRepair
  • 438 Answers
SOURCE: What do the numbers on the Kirby G5 beater bar end
The numbers on the beater bar end caps are used to lower the brush down as the bristles wear down. When you bought the machine, the brush roller started in the 1 setting. One year later, after the bristles have worn down, you can move the numbers to 2, then 3, etc.
It's a pretty neat concept by Kirby, it prolongs the life of the roller brush significantly.
Hope this helped you,
Chris Jones
GoVacuum.com
Posted on Jan 08, 2011
Kirby vacuum-The beater bar is turning, but the light is not on. Is something else wrong?
Check to make sure the magnet on the roller is on the side with the coil (this activates the light). You may have installed the roller with the wrong ends in the opposite sides.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 11, 2014 | Kirby Vacuums
What do the numbers on the Kirby G5 beater bar end caps mean?
Chris Jones
GoVacuum.com
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Belt is on roller. Not sure how and how to reattach
When you put the beater bar back in have the belt hook in the normal operating position. Hold the whole beater bar housing upside down and turn the hook. It will grab the belt. Once it does, keep on turning. It will get tough to do, but turn it until you can't go anymore. Then put it all back together!
Oct 29, 2010 | Kirby G5 Bagged Upright Vacuum
My kirby vacuum is not picking up what can i do to resolve that problem
is the beater bar turning when put under a load? Kirbys are great machines but the beater bar (bar under the machine that turns) does wear out. I am sure you already cked but check your belt .
Aug 08, 2010 | Kirby Vacuums
The brush isn't spinning
the belt is broke. you can buy a new one for around 5-10 dollars at target or walmart, or loews or homedepot.take the screws of the bottom panel to expose belt. you will have to pull out the beater bar to replace the belt. just pull on it after the bottom plate is removed the beater bar just slides out. slide the new belt down the beater bar then pull the belt over the spinning pin. now stretch the beater back to its original position it should slide right in. replace the bottom plate and your back in business
Jul 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Jun 17, 2009 | Kirby G5 Bagged Upright Vacuum
The beater bar on my Kirby Generation 3 does not turn when it is on. I took it off and cleaned it but I am not sure which way to put beater bar back in. The ways I tried, it still doesn't work.
Good Luck
Mar 01, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Kirby 2hd how do i put the belt on this vacuum thanks
On the Front of sweeper is a Tab Turn it and it will release the Beater Bar assembely Put the Belt around the Bar and put the Belt on the inner tab Turn and the Belt should go around motor Good luck ttech
Jul 24, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Belt burning
the beater bar probably needs to be removed & cleaned. the shaft & bearings get bound up with hair, string, etc.. with the belt off the bar, it should spin fairly easily. if it's hard to turn,(belt off) then it's bound up.
Jun 14, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
