its a casio pro trek PRG-50. it has an alti, baro, comp, witch all do not read when activated. the light also does not work. it shows the err message after it comes back on after in hibernate.
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
where would a get a replacement back for an square armani watch purchased about 8 years ago,and...
(More)
where would a get a replacement back for an square armani watch purchased about 8 years ago,and about how much,ta
