Question about Car Audio & Video
Nissan a31 radio wiring - Car Audio & Video
I need a 2000 nissan sentra wiring diagram because my pioneer stereo was hooked up wrongn and now have no dash lights
I can provide the radio wire colors and each function of the wires by color. 2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Feb 28, 2018 | Nissan Cars & Trucks
2013 Nissan Frontier S, radio wire diagram.
2013 Nissan Frontier Car Stereo Wiring Guide
Car Radio Battery Constant 12V+ Wire: Yellow
Car Radio Accessory Switched 12V+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Dimmer Wire: Gray
Left Front Speaker Positive Wire (+): Brown
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Dec 02, 2016 | Nissan Cars & Trucks
2002 nissan sentry xe radio wiring color code
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Oct 18, 2016 | 2002 Nissan Sentra
Nissan oil capacity
what is my oil capacity for 1993 a31 nissan cefiro
Jan 10, 2014 | Cars & Trucks
Sport fuse
did you check all fuses? yet? in both boxes?
first off the schematic (516pages) is here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
so you look any time and see why.
ill direct you to the pages.
the radio too can be complex. ext. amps. ill assume its 100 % DEAD
ill do radio dont play in run pos. of ign. sw., (easier)
there are 3 Cherokees, gas, desiel and export. so> and ENGINE! size
so every page is repeated 3 time. you sort that
6 fuses involved here, just for the freaking radio
but fuse 17 is the key fuse. see that. and the marking
RUN-ACC A31 , in JB (bad A31 power feed is the prob)
fuse 17 marked, X12-16rd/wt
fuse 18 kills windows. and is A31 feed too.. hummmmm
are both fuses blown, might check that..?????
so we look now at A31 (fuse 17 and 18 measure 0ohms with meter)
A31 goes to the Ignition switch, USA RHD GAS car, is most
complex and the first section of the switch has a pin3 to pin4
jumper. this jumper allows A31 power feed to reach the things
you find are dead. see page 8w-10-15 or pdf 35
see pdf page 240 for radio wires.
so what is wrong, i dont know,
but my voltmeter will tell min in 1min flat
got 12v on the A32 feed?
yes, then F17 -18 blown.
if not the jumper is bad in the ign. switch
Sep 24, 2013 | 1999 Jeep Cherokee
Nissan cefiro engine diagram
sa blumentritt rizal ave ext. meron yan.
May 21, 2013 | Vehicle Parts & Accessories
Audio wiring diagram for 04 nissan navara needed. with colour coding please
This model is also called Nissan Frontier2001-2004 Nissan Frontier (North America) Nissan D22 Navara (Australia).
Then, check this:
2004 Nissan Frontier Truck Car Radio Stereo Audio Wiring DiagramCar Radio Battery Constant 12v+ Wire: PinkCar Radio Accessory Switched 12v+ Wire: BlueCar Radio Ground Wire: GrayCar Radio Illumination Wire: Red/BlueCar Stereo Dimmer Wire: Red/YellowCar Stereo Antenna Trigger: N/ACar Stereo Amp Trigger Wire: N/ACar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: N/ACar Audio Front Speakers Location: N/ALeft Front Speaker Positive Wire (+): PinkLeft Front Speaker Negative Wire (-): BlueRight Front Speaker Positive Wire (+): WhiteRight Front Speaker Negative Wire (-): BlackCar Audio Rear Speakers Size: N/ACar Audio Rear Speakers Location: N/ALeft Rear Speaker Positive Wire (+): Light GreenLeft Rear Speaker Negative Wire (-): VioletRight Rear Speaker Positive Wire (+): BlueRight Rear Speaker Negative Wire (-): Pink
Hope this helps.
Apr 23, 2012 | Nissan Navara Cars & Trucks
Radiator
hi a nissan a31 cefiro or nissan c33,c34,c35 laurel radiators will work fine they are the same radiators as all r32's or a radiator from an s13,180sx,240sx with an ca18det engine will work aswell
Jul 26, 2010 | Crystal Decisions NISSAN SKYLINE GTR R32
1995 nissan pathfinder XE 8 speaker wiring COLOR CODES
1995 Nissan Pathfinder Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Blue
Car Radio Dimmer Wire: Red/Yellow
Car Radio Antenna Trigger: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Blue
Right Front Speaker Wire (+): White
Right Front Speaker Wire (-): Black
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Roof Mount
Left Rear Speaker Wire (+): Light Green
Left Rear Speaker Wire (-): Purple
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
Nov 20, 2009 | 1995 Nissan Pathfinder
Hi i have a 1989 Nissan Cefiro and having a
there should be a small mark on the block and indentation
Jul 05, 2009 | 1989 Nissan Maxima
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
