Question about Craftsman Air Tools & Compressors
Problem with the power button of my drill craftsman 1/2
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: caN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Try heating it up with a torch and tapping it off with a punch
Posted on Jul 24, 2009
  • 304 Answers
SOURCE: Does the 18volt 1/2 M18 have a 'reset' button? I was drilling a hole when the auger bit got jammed, stopping the drill. no power despite having moved forward/reverse button and removing and r
No reset buton I know of. Usually they reset once they cool down after a few minutes otherwise I suspect it's an internal fault.
Posted on Dec 26, 2012
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
Hammer drill wont drive
It sounds like the gear inside sheared the teeth. You can check with Craftsman to see if you can get a replacement gear.
Apr 07, 2014 | Craftsman Professional 1/2 in. 8.0 amp...
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
What drill to use with craftsman model 335.25921. drill press
craftsman is very powerful and old machine. If you want to know about the best drill go to the website...
Best Drill Press For DIY Professionals In 2018
Jul 07, 2012 | Drills
I have a Milwukee Drill - 1/2
http://www.ereplacementparts.com/
Sure it can be fixed. Here is a link that you can get a diagram and order parts. It is prob just the brushes.
Jun 02, 2010 | Craftsman 3/8" Corded Drill
I have a 19.2 volt charging stand and want to know
go to the sears site and you will find the manual button, click it and when prompted enter the model number of the drill. mine is 315.116890 for my 19.2 volt drill.
May 14, 2010 | Craftsman Drills
The drill has a short in the electrical. You have to get the trigger just right to make it work.
replace the trigger. you should be able to find one at craftsman website. if not call te costumer service there.
Mar 04, 2010 | Craftsman 1/2" 1/2 Inch Professional Drill...
CaN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
Jul 24, 2009 | Craftsman Drills
Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Feb 08, 2009 | Craftsman 4" Drill Press Vise, Side -...
Air Tools & Compressors Logo
59 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
