I can't get my Loewe TV to tune to my sky system
2 Suggested Answers
  • 325 Answers
SOURCE: Cannot get my sky guide to respond on my Loewe
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Posted on Sep 01, 2009
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Programing a remote eur7623x60
i have an emerson tv,an have not found a remote to work the tv,but,i have tuned it in to sky,by holding the channel and audio button up,it switched to av,so sky came in,all i can say is keep trying
Jan 16, 2010 | Panasonic SC-HT690 System
I have a sky splitter going into the back of my LG tv but I cannot tune it to receive the signal. Helo..
Try to tune with a direct TV antena if it works the problem is with the sky spltter, if not the problem is with the tunned system of the LCD...
Oct 01, 2009 | LG M227WD-PZ LCD TV
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
step one:
Step 2:
Step 3:
Hope this helps
Little Dish Fitter
Sep 01, 2009 | Loewe ARC332 32" TV
Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Jan 09, 2009 | Televison & Video
Setting up 42lg3000 with sky and lg home cinema dvd system.picture and sound from dvd.poor picture and sound from tv speakers only from sky .please advise on correct wiring connections for this set up.TV...
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Nov 29, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Tuning in SKY remote control with Orion TV
buy a better telly
looooooooooooooooser
Dec 17, 2007 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
