Question about Oreck Magnesium Upright Vacuum
Cover over left wheel has come off . Can I snap it back on?
None
My wheel fell off where cani get it fixed
Those wheels have a fixed axil that goes bad. A new wheel will fix that.
Sep 05, 2014 | Vacuums
Troubleshooting dyson dc01 upright hoover
If you are referring to the bearing cover on the wheel, this appears to be purely cosmetic. The disc is clipped onto the wheel and can easily be replaced IF you have not broken off the latches.
Aug 19, 2014 | Dyson Vacuums
The brush on my hayden 6000 supervac is not rotating when power is on and i can't figure out how to open the vac to get to the belt. help please
First you will want to remove the light cover. this can be done by pusing as you look at the front of the powerbrush on both the left and right side of the head.
There you will find the lightbulb and 2 screws to remove. Remove both of the screws and turn over to pry with a screwdriver at both the sides of the powerbrush to remove the top cover.
Once you have the lens cover off you will also see in the plastic the belt change instructions.
When you want to put the top cover back on, it will act much like a hinge, hook it on to the front of the head where the brush is, and snap it back into place at the back.
Nov 04, 2010 | Hayden Industries SuperVac 6000 Central...
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
Need to replace vacuum door
I pried up the back of the cover holding the height adjustment wheel and was able to snap the cover axle with the cover installed into place.
Jan 30, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
May 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do I remove the housing cover on a westinghouse vacuum?
Remove clear snap-in lights lens. Remove both lightbulbs. Where the bulb sockets are there is a screw, remove them. Then simply pull up on the housing from the rear where the wheels are and remove the top cover.
Dec 28, 2008 | Westinghouse WST1500 Wired Special Edition...
Hoover steamvac f7431-900
They should just pull out. They are just posts that go into the columns, a tight fit holds them in place.
Jul 28, 2008 | Hoover F7431-900 SteamVac Vacuum
Oreck Magnesium Upright Vacuum Logo
42 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
