SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
SOURCE: we have a Honeywell smartfit central heating
go to
http://www51.honeywell.com/honeywell/
and enter your model number on the right side near the top.
Hank
SOURCE: honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
SOURCE: My honeywell smartfit central heating
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is move the slider to the auto or once or cont position this should turn the system on.
SOURCE: My Honeywell Programmable Thermostat RTH2410
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You need to reset the t-stat and totally reprogram it...
Look in your manual how to do that or...
Here is a tip that tells you how to get a manual for most any Honeywell product
online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Testimonial: "Manual said nothing about reset procedure. However I started programming from the beginning and all is well so far. "
