Question about Vizio L37 Television
Samsung hl t5676s picture to dark - Vizio L37 Television
Screen is too dark
try turning up CONTRAST or COLOR or TINT or HUE hope this helped..... how bright is the room is the tv easier to see at night if the sun is hitting the screen that will make a big difference..
Nov 18, 2012 | Samsung HL-T5676S Television
Picture is slanted left to right.
Check and replace the main digital processor board. Synchronization problem, along with phase.
Aug 19, 2012 | Samsung HL-T5676S Television
How do i reset my lamp hour hl-t5676s
There should be a blue switch behind the lamp cover on the rear of the unit.
Feb 28, 2011 | Samsung HL-T5676S Television
Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
Feb 14, 2011 | Samsung HL-T5676S Television
The tv wont turn off without unplugging it
power button sticky ir remote sensor bad or dmd board problem most failures with samsung seem to be dmd board related if not the bulb or ballast
Jan 02, 2011 | Samsung HL-T5676S Television
Our 55" Samsung DLP television has white dots all over the screen. Day after day, more seems to appear.
The DLP tv projection light engine is the cause.This problems,very expensive to repair or replaced the projection light engine.Samsung know about this flaw in the tv design.Talk to them,make a deal with them about it.Help u repair it.
Sep 27, 2010 | Samsung HL-T5676S Television
My Samsung HL-T5676S Television comes on, then
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Good Luck....
May 21, 2010 | Samsung HL-T5676S Television
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
Vizio L37 Television Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
